a ha I'm in
So I've decided to build a Perkasa 49" with a fibreglass hull.
I was told a Torpedo 850 would do the job fine and so I purchased one, however I then decided I wanted 3 props so bought two 600 motors to sit either side of the 850, but then looking at the different size props I thought it looked a bit on the daft side so have now scrapped the two smaller motors and will be purchasing two more 850's. Which speed controler would be required.
Now I have been looking for a wood sealer to coat all the wood work in but trolled through B&Q only to find varnish and the likes nothing saying sealer on it. So could you point me in the right direction as to what to use.
I'm by no means any good at scratch building so my next problem is all the detailing in the "wheel house/cockpit" area, does anybody supply these ready built for 1/24th scale
Well I think I've asked enough to be going on with for the time being.
Thank you in advance for any information given I appreciate it.........I think the term "bitten off more than I can chew" springs to mind.
Cheers once again
