Author Topic: Sandy sealer  (Read 3123 times)
Sandy
Sandy sealer
« on: January 29, 2013, 10:27:02 pm »
What can I use to thin sanding sealer?
Thanks.
Sandy
Re: Sandy sealer
« Reply #1 on: January 29, 2013, 10:39:59 pm »
Depends on what it's based on, if cellulose then standard cellulose paint thinners
wicker
Re: Sandy sealer
« Reply #2 on: January 31, 2013, 02:00:21 pm »
how many coats are needed on bare wood
Re: Sandy sealer
« Reply #3 on: January 31, 2013, 02:07:11 pm »
 Sanding sealer is a pre- primer. So sand the wood to the best finish you can and then
 'slap on a coat' of sanding sealer and Gently sand again.  You'll soon be able to
 tell if it needs another coat.  ok2
 Remember your sanding (and sealer) IS the finished surface, all the paint does is change the colour!
wicker
Re: Sandy sealer
« Reply #4 on: January 31, 2013, 02:43:11 pm »
thanks for that Martin  will go ahead now with that work---Charlie
Re: Sandy sealer
« Reply #5 on: May 19, 2013, 04:00:24 pm »
The sanding sealer I have comes from Cornwall model boats and is labelled JP.... its xylene based so I use Xylene as a thinner.... this stuff really smells bad and the smell lingers so use outside if possible.
I normally thin mine down to with about 30% extra xylene for the first coat, this makes it really soak into the wood. then once dry another coat of undiluted SS and then sand, applying another coat if needed.
Page created in 0.098 seconds with 21 queries.
