if you increase the blade surface or size and put a bigger redaction on the current motor it will improve the towing ability , but not effect the free running speed a lotI like that statement, although she lacks the manuverablitiy for true tug towing events, but still I can have fun with her!
IN THE REAL WORLD hull design only lets the boat go so fast then it starts to push water and bury its self , like most tugs witch are over powered for there water line length I believe this is why tugs have the high bow, almost like the atlantic bows on some naval vesels?
BUT hook them up to a dead pull and they will move the earth ( love um )Thats the best bit! Nowt wrong with pulling 4 barges at a time!
and it should reduce the batterie drain (less load on the motor ) you can always free run at half throttle if you have to much POWER like i will have to do 60mm 4blade brass prop on 6 .1 red with mfa 540 on 12 v if you hold yer hand at the bow and not let it go forward at full noise it will bury the stern Is there such a thing as too much power on a Tug? from what I have seen the Dickie is fairly robust, and a couple of well handled examples should easilly cope with even 1:76 scale warships of the biggest proportions... Do you have any photos of the reduction set up please? Eventually I want to build a warship of some kind (probably a battle cruiser type) when I have gained alot more experiance in things model boat... I don't think I will try and bury the stern...
however I still think tug racing could be amusing!
Finally, Shiny parts
Sean
