Author Topic: 1:125 scale U-99 Revell kit...sunken.  (Read 8715 times)
eddiesolo
« on: February 22, 2013, 11:05:16 pm »
I always wanted to do a sunken U-Boat. So, got a rather small scale model and could not do it due to my disability...so, tried again and got a 1:125 scale Revell U-99 kit.
Once the kit was stripped from the sprues it was deburred and cleaned, then the fun began with doing damage/rust holes, drilling out the vent holes, inserting a pressure hull segment+pipe work through the saddle tanks.
Then it was detailed, paint, washes etc.
I have enclosed some pictures, not bad for a first attempt.
Various stages of coatings and effects.
Si:)
Re: 1:125 scale U-99 Revell kit...sunken.
« Reply #1 on: February 22, 2013, 11:07:22 pm »
Hi Si welcome to the madhouse so to speak....well you got to be mad to be here HA HA
That looks simply AWSOME
eddiesolo
« Reply #2 on: February 22, 2013, 11:15:35 pm »
Thanks Dave, appriciate the nice AWSOME!
It took around 30 hours total build time, enjoyed it though.
Si:)
« Reply #3 on: February 23, 2013, 07:22:15 am »
Very nice work.
Would you mind giving a bit more info on how you did the effects?
jimmy2310
« Reply #4 on: February 23, 2013, 07:38:12 am »
Very nice, very nice indeed. Looks realistic
Jimmy
“Damn the torpedoes! Full speed ahead!”
Sub driver
« Reply #5 on: February 23, 2013, 09:28:15 am »
Cannot see any pictures, any one else not see them
« Reply #6 on: February 23, 2013, 10:28:49 am »
Great job Ediesolo.
 Different.... very different!  :-))
(Photos reposted)
eddiesolo
« Reply #7 on: February 23, 2013, 10:32:31 am »
Very nice work.
No problems at all.
Once the basic plastic kit had dried the surface was very lightly sanded using a fine grade sandpaper, once done this was then washed to remove any plastic bits and left to dry. Then the model is coated in PVA glue-you can glob this on as it all adds to the effect in places. Once coated in PVA glue you then sand the areas, for a more smooth, rough looking surface, if that makes sense, use a childs sandpit sand as this finer or just use any sand, try not to get too many large pieces sieve if you can. Once coated leave to dry then seal the sand, I used a can of car paint in a brown rust colour-this is applied and like any spray painting nice even strokes, leave to dry and deatail with sponge paint washes.
Just to add, that this method is a lazy modellers dream as you do not have to be too careful in deburring and coating as it is the effect you want-so it works. This method can be used on sunken ships etc. For a larger scale model I would be more inclined to spend more time building up the layers as the scale means you can see the detail more.
Hope that helps.
Si:)
eddiesolo
« Reply #8 on: February 23, 2013, 10:36:12 am »
Jimmy
Cheers Jimmy. I trawled (see what I did there, being a nautical model forum.) pictures of sunken submarines to try and get a look between total rust and gaping holes to fresh, so the end was damage with concretion growth.
Si:)
Sub driver
« Reply #9 on: February 23, 2013, 10:38:34 am »
Thx martin now got visual..
eddiesolo
« Reply #10 on: February 23, 2013, 10:42:38 am »
Uploaded from photobucket, don't know why you cannot see them  >:-o Admin has re-posted some, but here is some more direct from my pooter.
Si:)
eddiesolo
« Reply #11 on: February 23, 2013, 10:43:57 am »
Great job Ediesolo.
Thanks Martin and thank you for re-doing the pictures.
Si:)
Davy1
  • Association of Model Submariners
« Reply #12 on: February 23, 2013, 12:15:19 pm »
That is really good!
Could I say (as a former diver) that THAT is a realistic wreck. Hollywood has done us no favours in portraying underwater subs wrecked or otherwise.
Only point I could suggest would be to have some tattered bits of fishing net on the model.
David
eddiesolo
« Reply #13 on: February 23, 2013, 12:27:39 pm »
David
Wow, thank you David for the kind words. I did research many pics to try and get the look of the model correct, it also depended on depth, many deep wrecks had little concretion while shallow wrecks tended to be rusted to bits, so a compromise of the two.
Funily I did toy with the idea of adding netting, but couldn't find any the right size.
Thanks again.
Si:)
« Reply #14 on: February 23, 2013, 12:42:30 pm »
Si:)
  :((     Is it me but those  pictures make me feel creepy.....      {-)
eddiesolo
« Reply #15 on: February 23, 2013, 02:04:21 pm »
LOL, yeah I suppose they do. I was going to try and do the pictures with a black background to give more effect. They do look creepy, the hatch in the sail I did in an open position...maybe the ghosts of the boat still lurk to trap unwanted visitors...
Si:)
U-33
  • K-157 Vepr. Akula-11
« Reply #16 on: February 23, 2013, 03:58:39 pm »
One thing...bend the scopes over.
eddiesolo
« Reply #17 on: February 23, 2013, 05:09:47 pm »
Do you mean straighten them Rich? I had an accident, dropped the boat due to my illness, then forgot about them. I see what you mean though, slightly off-centre, I'll see what I can do.
Si:)
DavieTait
« Reply #18 on: February 23, 2013, 05:43:02 pm »
Rich real sub subs normally don't have bent scopes lol
https://www.facebook.com/pages/Innes-McCartney/133017106838877
Have a look through Innes' galleries on facebook plenty of subs in there
Davie Tait,
Scotland
profesorul
« Reply #19 on: February 23, 2013, 05:46:07 pm »
HI,
I have NO words to say so I say only:UNBELIEVABLE WORK.   :-))   :-)   CONGRATULATION   O0   :-)) ok2 .
THANK YOU for enchant us with such a beauty.
MARIUS
U-33
« Reply #20 on: February 23, 2013, 05:48:23 pm »
No...bend them over at strange angles, it's not very often you see the wreck of a sub with scopes perfectly upright.
Sparky
  • sparky
« Reply #21 on: February 23, 2013, 06:13:38 pm »
Not only you Martin, I got shivers looking at them too!!
congrats to Si for your efforts.
eddiesolo
« Reply #22 on: February 23, 2013, 09:00:45 pm »
Interesting link, thanks Dave.
Si:)
eddiesolo
« Reply #23 on: February 23, 2013, 09:02:03 pm »
HI,
MARIUS
Very kind to for you to say Marius, thank you.
Si:)
eddiesolo
« Reply #24 on: February 23, 2013, 09:04:48 pm »
Ah, I see what you mean Rich. Yeah, some wrecks do have bent scopes, normally due to sail damage via bombs or depth charges, or due to shipping-trawl nets etc. But I have seen some with them bent out of shape.
Si:)
Page created in 0.147 seconds with 21 queries.
