Hi Shaun
With regards to tools. Depending on the type of modelling you will do, you may not need that many.
There are mini-table saws on the market. Some are very cheap others very expensive, have a look on Amazon too, as they ship to Malta. However, think about what you want the saw for, and others can advise on if it is needed. I have bought many tools that I have only used once, some I have never used.
If you are working with wood, basic tools can be as few as
- sharp knife (scalpel or stanley type)
- cutting board
- steel ruler
- household screwdriver set
- rubber bands, for holding things together
- masking tape, for holding things together and for painting
- sand paper, for shaping and fine trimming of wood. Sand paper can be glued to small strips of wood and used like a file for shaping.
These are enough to get you started.
You can also add
- some clamps
- jewelers screwdriver
- jewelers mini hand drill
Most of the above you can find in hardware/diy stores
I am sure others will add to the list.
