Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16   Go Down
Author Topic: Building the FV Cornelia Marie  (Read 147518 times)
chris gillespie
Re: Building the FV Cornelia Marie
« Reply #225 on: March 09, 2015, 09:34:23 am »
Lovely work Danielle
You and your wife should feel very proud of your efforts
Now get it on the water  :-)
MikeK
  • Utter Bloody Chaos !!
« Reply #226 on: March 09, 2015, 10:56:28 am »
Is that a choice because you have tried both methods ? Not that I have experience in this skill and my relationship with an airbrush has been mediocre, if that is what can be achieved using the 'dry brush' method then that will be my choice
missyd
« Reply #227 on: March 13, 2015, 04:17:55 am »
Mike I tried the airbrush once ... all the blue on the boat was airbrushed. But the mess it created in my workshop and cleaning all the stuff afterwards wasn't what I had expected.
Some more pictures of the built ....
cleaning up the wiring
Testing the lights
Danielle
MikeK
« Reply #228 on: March 13, 2015, 06:21:44 pm »
That just about sums up my attempts with the airbrush, more mess than results !
Your lighting came out spot on Danielle (no pun intended) It looks so realistic that it makes the room look out of place !  %%
missyd
« Reply #229 on: March 17, 2015, 07:49:21 pm »
Cleaned up the wiring ....
Added a hook and the cable
Cables on the 2nd crane added
Anchor and chain fixed
Danielle
jarvo
  • Etherow model boat club
« Reply #230 on: March 17, 2015, 09:58:14 pm »
Danielle.
Please put us out of our misery, put Cornilia Marie in the water and show lots of photos.
Wonderful work, been following from the start, brilliant
Mark
Tugs are for pulling
missyd
« Reply #231 on: March 17, 2015, 10:05:07 pm »
Danielle.
Mark
I'm sorry Mark ... first outing is planned for an end of April modelboat-show in Switzerland.
BTW the hull is completely empty ... I did not start with fitting the stuff inside sofar.
You have to be patient for some more weeks ....  ;)
Danielle
missyd
« Reply #232 on: April 03, 2015, 07:10:04 pm »
Did some more work in the last week.
Motors are wired and fixed in the hull.
Rudders and Servo connected by chain and sprockets
Danielle
« Reply #233 on: April 03, 2015, 08:34:38 pm »
That's the smartest twin steering I've ever seen.     :-))    :-))
ken
MikeK
« Reply #234 on: April 04, 2015, 08:07:44 am »
ken
Ditto !   :-)) O0
Corposant
« Reply #235 on: April 04, 2015, 09:33:09 am »
It seems to have everything going for it - simplicity (therefore reliability), robustness and neatness. Well done Danielle!
I see Anita hasn't been round with the vacuum cleaner yet.  %)
Mike (Another one!)
missyd
« Reply #236 on: April 05, 2015, 06:35:31 am »
Thanky you very much!!! Your postings give me new motivation to finish the project.
I did some more work .... Battery holder for 3x 12V (Motors and Lights) & 1x 6V (Waterpump)
...and the waterpump itself ... I used rubber spacers to prevent vibrations ...
Danielle
missyd
« Reply #237 on: April 08, 2015, 07:57:13 pm »
Some pictures of the wiring .... there are more wires than I thought ...
Danielle
MikeK
« Reply #238 on: April 09, 2015, 08:40:22 am »
Just noticed in your latest pics that there might be a bit of vibration from the stbd motor as there is a slight misalignment at the U/J.
You are probably aware of this already, but I'm just chuffed at finding my first small blip in this great build !      {-)
missyd
« Reply #239 on: April 09, 2015, 09:30:39 am »
@Mike: Yes I know ok2
I'll see if it creates vibrations or not. The motor unit has some rubber mats under it.
Danielle
MikeK
« Reply #240 on: April 09, 2015, 09:46:39 am »
Hi Danielle, I thought you would have noticed   :-))
It was probably just good old envy that prompted the post anyway !  O0
missyd
« Reply #241 on: April 09, 2015, 05:23:57 pm »
 :-)) The problem with the misalignment is the result of "absolutely no experience" and "it looks ok it is ok". ;)
Danielle
missyd
« Reply #242 on: April 15, 2015, 04:01:51 am »
Water pump for the crab tank feature is ready for action ....
Danielle
jarvo
« Reply #243 on: April 15, 2015, 10:45:47 am »
HI Danielle
Back to your post after several weeks, 2 things, you mentioned that when you sprayed the hull there was a terible mess, try hanging a damp sheet around the spray area, (DAMP) this causes the overspray to stick to the sheet and not go everywhere, the other or combined reason is that you posibly had the spray presure to high for the thickness of paint, this would also give a sandpaper effect as the paint is already drying befor it hits the surface.
Hope your problems wont stop you spraying, the effects and finish with practice can be superb.
Your photo of the speed controlers, are you fitting a plate above the rudders? if not please make sure the wireing cant droop down into the chain drive.
Mark
« Reply #244 on: April 15, 2015, 12:24:06 pm »
Danielle sorry to be picky but I can also see a potential problem in the wireing dept ....it is called Tamyia connectors....Personally I would change these for XT60 connectors which will carry a lot more current then those
Tamya ones
http://www.componentshop.co.uk/leads-and-connectors/connectors/xt60-xt90-connector
missyd
« Reply #245 on: April 15, 2015, 07:30:45 pm »
@Mark: Thank you for the very good idea with the damp sheet!!! I'll try this with my next trawler model. No problem with the chain for the rudders ... everything stays in place and out of the way!
@Dave: I know the Tamyia connectors are rubish! But the drawn current is very low (only 35mm screws). I never used other connectors a the Tamyia ones ...
I added the rubber sealing on the deck.
Some pics of the CM ...98% finished ...
Danielle
« Reply #246 on: April 15, 2015, 08:36:59 pm »
Lovely work .     :-))     :-))
ken
missyd
« Reply #247 on: April 17, 2015, 09:16:10 pm »
Thank you very much Ken.
Phil is ready for work ....
Danielle
« Reply #248 on: April 17, 2015, 09:21:18 pm »
Phil needs a cigarette and a can of red bull :)
I do like this build
missyd
« Reply #249 on: April 21, 2015, 11:24:15 am »
He stopped smoking and drinks only healthy water .... ;)
The FV Cornelia Marie is 100% finished and we'll show her this weekend at a swiss model ship show in Wohlen/AG.
Danielle
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16   Go Up
