If you are a complete novice to model making then I would suggest starting small-do some static kits-plastic model kits, try some small ones first-try different glues, paints etc, then move on to larger scale model kit. Once again this will give you feel of doing various boats without the cost of a rather expensive kit and little to no experience. Try and get a cheap second hand RC model and strip back make it good again, I have been model making on and off for years and still find different techniques.
As has been said, scratch built can be daunting so a kit will need less tools and time but get you used to working with clamps, glues, paints etc.
Si:)
Just to add there is many different types of products used. I use various super glues, contact adhesives, industrial adhesives like no-nails but stronger, even silicone sealant. Clamps are anything from metal to plastic to various size rubber bands, dress makers pins are useful for holding planking together until glues go off, masking tape is okay for various places but can be weak on curves so no good. Car filler can be used on certain models, brass etchings are normally soldered so using a soldering iron would be a benefit if you are thinking of going down that route. Best course of action is to play about-like I said some cheap plastic model kits will help you in doing smaller things-then move up in scale.
