Author Topic: Subs  (Read 2388 times)
Gazza
  • If its to windy to fly I'm boating
Subs
« on: May 27, 2013, 10:42:48 am »
you know I'm so curious as how to see where your going with a sub ( I'll state as in under water before some one asks  :}  )
As I fly planes would a FPV ( first person view ) video camera work . .
Just a thought
http://www.youtube.com/watch?v=d_Adb1HMXTM
retired and loving it
Re: Subs
« Reply #1 on: May 27, 2013, 10:55:04 am »
Super, this is what we need, especially the low swoops over the road.  :-))
 Wonder if the pilots name is Richard Head?
Gazza
Re: Subs
« Reply #2 on: May 27, 2013, 10:59:27 am »
 %)  There's Always one in every forum  <*<
Re: Subs
« Reply #3 on: May 27, 2013, 11:44:50 am »
There certainly is.   O0
imsinking
Re: Subs
« Reply #4 on: May 27, 2013, 12:41:05 pm »
 {:-{  Wont work underwater apparently , transmissions are either 2.4ghz or 5.4ghz? & you'd need a towed surface array to get the signal out . . . it'd just be something else for the surface runners to collide with  %%   >>:-( wouldn't it be great if you could see where you were going underwater tho'? it would make the crash all the more spectacular  {-)
Bill
Gazza
Re: Subs
« Reply #5 on: May 27, 2013, 12:50:51 pm »
So no radio gear works under water ?
you do surprise me so when a model sub goes under then you have no control over it  %%
thegrimreaper
Re: Subs
« Reply #6 on: May 27, 2013, 01:14:35 pm »
Now Now Bill you know surface runners run into subs even without a towed array. <*< <*<
Gazza Radio gear do`s work under water as long as you dont try and use 2.4 gigs as the signal will not penetrate water. Model submariners use 40 megs and you have full control of the sub down to probably 15 ft unless the water contains a lot of particals , is salt water or even swimming pool water they all reduce the safe controlable deapth you can go as to FPV with a sub water is not as clean as air so unless you are in a swimming pool or fresh clean water you wont see much anyway best way to see whats going on under water is to fit a keyfob typ camera into a water tight container recording onto a micro sd card and watch it later
Regards Mark
Don't lie, thieve, cheat or steal. The Government do not like the competition.
Gazza
Re: Subs
« Reply #7 on: May 27, 2013, 01:16:45 pm »
Top man mark that explains a lot well put young man  ok2
hmsantrim
Re: Subs
« Reply #8 on: May 27, 2013, 02:14:28 pm »
Hi gazza.
 Go and have a look at this. http://www.youtube.com/watch?v=Ioc97woAXDs
 Frank  :P
Gazza
Re: Subs
« Reply #9 on: May 27, 2013, 02:59:15 pm »
brill and the pictures are so sharp and clear . .  very nice  :-))
thegrimreaper
Re: Subs
« Reply #10 on: May 27, 2013, 07:48:58 pm »
Also Gazza check out my own video taken from a Thunder Tiger using an 808 key fob camera. Video was taken at New Brighton pool the home of the Wallasey model boat association, the clear water is attributed to the members cleaning the pool
http://youtu.be/CyCgqfn_KHE
Regards mark.
