I had a UBEC feeding my Rx and my Action Noisy Thing.To keep the voltage at 5V
I had a problem setting up my brushless ESC so instead of going to get my
Tx to sort it out I decided to use my servo tester instead so with
the ESC disconnected from the Rx I had to fit the BEC red wire back into
the ESC plug, all went well, set the thing up unplugged the servo tester
Went for dinner, Came back to the workshop Tx in hand,
Plugged the ESC back into the RX switched on the Tx
connected the main battery and nothing worked
the Rx and Noisy thing won,t work.The led on the UBEC went dim.
You guessed it I did,nt remove the red wire from the ESC bec
and that idiot mistake has cost me an Rx and a Noisy Thing
Any one need a 15w amp
john
