Hi Manfjourde,
I assume you mean this video:
http://www.youtube.com/watch?v=CJQuwqAi-gAThe set-up mentioned is a compilation of mismatches...:
Leopard brushless motor 3900KV, Hobbywing EZrun 25amp ESC, 7.2v NIMH 2000mah, M4 35mm sports prop.
- the only Leopard motor I can find with 3900Kv is this one:
http://www.ebay.com/itm/ePacket-to-USA-Leopard-RC-540-3650-3900KV-4-Poles-Brushless-Motor-for-Car-Boat-/281013315896?pt=Radio_Control_Parts_Accessories&hash=item416db2e938It's rather big (overkill springs to mind...) for the boat in the video.
Its rated at 1300W, thats a decent motor for a 80 cm surface piercing drive monohull (not competition material, as the can is too short, but very fast).
- On 7,2V NiMH 2000mAh that would mean a max ampdraw of 180A.
No way a NiMH pack can deliver that kind of current, the result is in the video, the motor is severely bogged down due to the limitation of the NiMH, which are struggling to keep the motor running.
At the end of the video, you seen the ESC cutting off, as the batteries are fully depleted (and hot!).
The 25A ESC only survives, because the NiMH can't deliver the current the motor will try to draw.
Put in a Lipo packet that cán deliver and the ESC will go up in smoke.
The prop is no match for the Leopard, hence the modest speed.
To be honest, a 3900Kv motor on 2S gives you the rather ridiculous 25.000 rpm under load, that's a blender...
If the 380 size is an outrunner, you'll have plenty of 'pep'. An Inrunner that size only has a tiny rotor and relies on revs, in stead of torque.
Gearing down 2:1 would allow for a 'normal'(=efficient) size prop without overloading the (high revving) motor.
Too much revs on a submerged prop only results in cavitation (foam) without the matching speed.
If the prop eventually does bite, the boat will ride so high, it'll topple from side to side, or (most likely) run on the right side and half the bottom due to the torque of the prop.
Needles to say controlling it will be a gamble at best...
Regards, Jan.
