Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: Aziz - Hawaii build  (Read 106536 times)
seathug
Re: newbie from hawaii
« Reply #100 on: June 03, 2014, 07:37:37 pm »
Looks like the wrong props to me.
You need kort props for max efficiency.
If the shafts are M4 thread, then a pair of
M4 Kort props are what you need.
Hi netley
Drive shaft that comes with the kit is an m4 I think
Hopefully that m4 will looks as good as the m5
I like how it looks
seathug
Re: Aziz - Hawaii build
« Reply #101 on: June 03, 2014, 07:40:58 pm »
Topic renamed  :-)
Thank you sir admin :)
I will be the only one with an aziz on this island
Cant wait to get it wet in waikiki beach
Maybe hooked up  a go pro and bikini watch  {-)
seathug
« Reply #102 on: June 03, 2014, 07:55:34 pm »
In HAWAII you have guys who maintain yachts
These guys have cartridges of glue to repair and fix the windows of boats
You can stick everything on everything, and that reflects.
 I make  eight kits MODEL SLIPWAY, I stuck all my decks with this glue and I have never had problem, I also stuck of the PVC on the hull with no problem at all.
It is good for the big solid and tight collages(stickings).
That catches up the space.
You put it generously and you cut what exceeds with a cutter when it is dry
Hi gazou
At first I didnt know where, what types of glue I needed
I went down to fiberglass hawaii
I end up getting a glue they used on surfboards
I must say its the best glue I have ever used
this glue will stick anything to everything
And its waterproof hard as hell when it dries
And its clear
One type of glue for everything on this aziz
I can also use it as a gap fillings and just sanded shaped it down  O0
with all these boats fishing boats barges warships tugs ferry etc. On this island
You would think youll see lots of scale rc boats
 BUT NO lol
seathug
« Reply #103 on: June 04, 2014, 07:49:58 pm »
Update
I called harbormodels about my props problems
They offered me a new props
I asked them about the old props
If I can send it back to them
But they said its not worth shipping it back to them
Since the shipping cost is high
 I asked them to hold on the props for not
Since ill be ordering my motors this friday
Figured save some from shipping
Least what I can do for them losing money on those props
Uses Propulsion Package SLIP02 on 6 Volts Which Includes:
TWO(2) 6:1 Geared Motors
TWO(2) 6mm X 4mm Couplers
ONE(1) VIP40 AMP Speed Control
This is the motor listed on their website
Like I mentioned before
This is my first time building anything
I dont know what's the best motor or gadget for this boat
If I know I would get the best I can put on this aziz  {-)
And those two extra props I have?
Ill make a crate or palette and put it on the cargo bay O0
seathug
« Reply #104 on: June 05, 2014, 08:28:15 am »
Ok now im really confused
Someone told me I should go brushless
Its the best motor to run on the aziz
Like the turnigy
I dont understand the part of the esc needs to be programmed?
Should I go brushless of I should just go with the recommended power gear for this aziz
« Reply #105 on: June 05, 2014, 09:49:36 am »
Tugs and displacement hull need nice slow revving motors, about 5,000 to 10,000 RPM.
Not many brushless motors like such slow speeds. You can get 'sensored' motors and controllers but
you pay a premium for them. ( I think the 'rock climbing' cars use sonsored motors. )
eg. http://teamnovak.com/products/index.php?main_page=product_info&cPath=5&products_id=524
Some modellers have successfully used brushless in displacement type hull but sorry I don't know the motor specs....  {:-{
Also see:
http://www.modelboatmayhem.co.uk/forum/index.php/topic,13538.msg130068.html#msg130068
NFMike
    • Plague Marine Services
« Reply #106 on: June 05, 2014, 11:12:19 am »
Like the turnigy
Brushless is probably going to become 'standard' over the years to come, but given your (and no offence meant) apparent technical understanding I'd say stick with what is recommended. There are some long threads on MBM of people trying to help others programme ESCs, so get something that is plug-and-play - ie. purpose built marine ESCs with a couple of standard motors, which is probably what that SLIP02 package gives you. And Harbor Models will be able to support you and sort any faults, etc.
seathug
« Reply #107 on: June 05, 2014, 07:51:56 pm »
Yeah youre right I think ill stick with whats recommended for this aziz
Im no techie by all means
Unless theres a brushless that is plug and play
None of that programming crap  {-)
Lany way I just want to keep it simple for now
I can always changed everything later on I guess
I wonder what is the biggest rc scale tugboat kit fiberglass online
I may want something that can pull me on a row boat someday hahahahha
seathug
« Reply #108 on: June 06, 2014, 08:04:26 pm »
The motor ill be using on my aziz
Robbe Geared Motor
5.5:1 12Volt
4mm Shaft
2 of these and
1marine viper esc
seathug
« Reply #109 on: June 06, 2014, 09:14:46 pm »
Robbe Geared Motor
5.5:1 12Volt
4mm Shaft
2 of these and
1marine viper esc
How do I connect this to driveshaft?
Couplings
Both ends of my driveshaft hqs thread on them
« Reply #110 on: June 06, 2014, 09:18:14 pm »
You are going to need a flexi coupling with a thread on one end and a clear hole with a grub screw on the other.
You may need to buy two standard ones  (one threaded and the other plain)  and swop the ends over.
Ken
seathug
« Reply #111 on: June 06, 2014, 09:27:38 pm »
Hi ken thanx for your reply
I just hope harbormodels has what I need to connect it
This what I found on their site
http://www.harbormodels.com/site08/main_pages/propulsion.htm
NFMike
« Reply #112 on: June 06, 2014, 11:45:01 pm »
Looks about right.
I suggest you get:
2 x Kardan Style Motor Couplers, with the couplers needed for your motors and shafts
2 x MFA Coupler Body
2 x Super Navy Coupler
You can then combine those into a pair of proper Kardan shafts (like the 'Coupling for 2.3mm to 3mm Shaft' further down the page. That will make alignment of motor and shaft a lot less critical (ie. difficult) than using a single joint coupling.
Ends up like this:
seathug
« Reply #113 on: June 07, 2014, 12:11:15 am »
Which motor can give me more thrust?
Someone told me 5 5:1 gets me more thrust?
This aziz will be running on the beach
I need all the thrust I can get to get through those waves
Nordlys
« Reply #114 on: June 07, 2014, 05:52:25 pm »
Sailing your boat in the sea?
Are you serious!
That would worry me mate....
N
seathug
« Reply #115 on: June 07, 2014, 08:40:12 pm »
Are you serious!
N
Ohh yeah
On the beach
Its all I have in hawaii
As you know hawaii -oahu is a  island
So this aziz will go on the beach
Hooked up a go pro and go biking watch in waikiki {-)
Ill make sure this will be on youtube :-))
To see if itll turn in to a submarine or not hahha
NFMike
« Reply #116 on: June 07, 2014, 11:26:32 pm »
There is a Youtube video somewhere of an Aziz 'at sea'. German IIRC, probably from a year or two ago. Might be worth searching it out.
seathug
« Reply #117 on: June 07, 2014, 11:53:00 pm »
Oh I saw that on youtube
That was the reason I picked the aziz as my first build
Hopefully it can handle the waves just like that one
ill make sure everything will be water tight
seathug
« Reply #118 on: June 08, 2014, 06:11:50 am »
Just got done with my bow thruster
I used the tube of the dummy thruster that came with the kit
To extend it longer  :-))
jbweld it from the inside and the outside :-))
Lot's of extra plastic to cut off
with the dremel it makes a lot things easier
pretty happy how it came out O0
seathug
« Reply #119 on: June 09, 2014, 06:07:36 pm »
I just made the biggest mistake on my aziz so far
I totally forgotten a little space for the rudder to moved around
Now its sitting on the glass fiberglass
And the kort nozzles doesnt fit in right
Now I have to dig it all out again
Crap >>:-(
SailorGreg
« Reply #120 on: June 09, 2014, 06:29:54 pm »
It's not a mistake, it's a little piece of experience to add to all those other little pieces you'll pick up as you go along.
Although that doesn't make it any better when you screw up!   >>:-(
It'll look great when you've fixed it.
Greg
seathug
« Reply #121 on: June 09, 2014, 06:58:58 pm »
Hi sailor greg
Thanx  that made me feel  a lot better O0
I just finished digging it out :}
I think ill wait for my props before gluing it again
They sent me the wrong props m5 with 3 blades :((
I needed the kapland 4blades m4 props :-))
seathug
« Reply #122 on: June 11, 2014, 03:34:57 am »
My new indoors work bench
I got it at a good deal
This work bench was discontinued
Due to missing parts on those boxes
they were pulling it out of the store when I asked
If I could get the display instead O0
Got it at a half price :-)) :}
all metal with wooden table top
I didnt like the metal top
GAZOU
« Reply #123 on: June 11, 2014, 08:11:58 am »
Hello
When I see this subject I wonder to what can be of use the forums.
The manufacturer has to tear extract hair!
A so beautiful kit ............
seathug
« Reply #124 on: June 11, 2014, 04:34:40 pm »
Hi gazou
It is a nice kit
Am glad I have one
To bad though I made a mistake with my A arm had to dig it all out
Im glad I dig it out instead of cutting my rudder
This time around I will make sure ill do it the right way
Waiting for my props motor and couplings
Hopefully itll arrived tomorrow :-))
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16   Go Up
