Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16   Go Down
Author Topic: Aziz - Hawaii build  (Read 106422 times)
seathug
Re: Aziz - Hawaii build
« Reply #225 on: June 30, 2014, 07:51:48 pm »
 {-) wahahahha
That made my day
Oh im confident now that this aziz will sail
I got the nozzles in placed now
Its the hardest part in building my aziz I think
Aligning all those parts nozzles props has to be centered
I dont like those fittings
If only I have a welder ill fabricate my own fittings for for the running gears
The reason im asking now for those things is
So I have an idea about the tray ill be using inside the hull
Tray for the battery will prevent it from sliding all over the place when the waves hits it from the side O0
seathug
« Reply #226 on: June 30, 2014, 07:55:51 pm »
By the way inertia
Which hitec brand have you used before?
Thanx
inertia
« Reply #227 on: June 30, 2014, 11:07:47 pm »
Ranger 3 40MHz
Focus 6 40MHz
Optic 6 2.4GHz
seathug
« Reply #228 on: June 30, 2014, 11:13:16 pm »
Thanx ill get the optic 6
By the way do you know anyone would be willing to make a hull for me
For a price of course
Im trying to build something like this
But I cant find any hull
seathug
« Reply #229 on: July 06, 2014, 04:45:56 am »
I just recieved my order from. Harbormodels
I ordered it online last week but igave them a call when I didn't receive it
I found out computer is down
So I just told them The things I needed
portholes and stanchion s or something
and my motor mount
Heres my problem
how can this thing be a motor mount?
motor bracket?
I would think bracket and mount have a huge difference
So can someone tell me what in the world is this thing for
Im scratching my brain trying to figure out what in the world is this thing for
seathug
« Reply #230 on: July 06, 2014, 04:49:50 am »
I know there's no way for this thing to be a motor mount for my robbe geared motor
Can someone tell me where I can order two motor mount
And please let it be in the us
CyberBOB
« Reply #231 on: July 06, 2014, 05:34:08 am »
Does this look right?
seathug
« Reply #232 on: July 06, 2014, 06:10:09 am »
Hi bob
I have seen that thats why I ordered mine
I cant figured out whats holding the motor from that thing to fall off
 {-)you just stick it in and thats it?
I thought the motor would be bolted on something
I feel and sound stupid right now
Ok let say I put it on just like that then what isnt the motor supposed to sit on something
This makes more sense to me
CyberBOB
« Reply #233 on: July 06, 2014, 08:01:40 am »
I've got no idea.  I just found the picture on Google images, and was hoping it would be of help.
Google turned this up:
http://www.modelboatmayhem.co.uk/Modellers/Spike/Antji.htm
Looks like it is glued together.
seathug
« Reply #234 on: July 06, 2014, 09:10:17 am »
Thanx bob
This is crazy
That plastic jig is a waste of money
Im going to make my own from a fiberglass
hmmm maybe I can use that plastic
Next my portholes
I thought those glass or plastic would fit inside the portholes but its not
So Im Guessing those glass or plastic will be glued outside the portholes?
« Reply #235 on: July 06, 2014, 11:46:31 am »
Blimey, that's an old Mayhem page!  :o
CyberBOB
« Reply #236 on: July 06, 2014, 06:33:51 pm »
Google knows all!
I've always made my own motor mounts as well.
Usually I make them out of aluminum (aluminium for those outside North America!). Basically I just cut out a rectangle of aluminum, bend approx. 1/3 up at a 90 degree angle (or whatever you need to match the angle of your prop shaft), and drill three holes in it, one for your output, and two for mounting screws.
Aluminum works well for this as it is very easy to cut with a hack saw, files easy, won't corrode too bad, and may help keep the motor cool.  I usually glue the mount to the hull with something like silicone, as you can remove the mount at a later date by sliding a blade between the mount and hull.
You may need some short tubes to act as spacers between your mount and the motor, as the screws are back aways due to the gearbox.
Of course there are a lot of other ways of making mounts as well, I'm sure you will get some other ideas by poking around the site.
seathug
« Reply #237 on: July 06, 2014, 07:02:13 pm »
Hi bob
Im thinking of fabricating my own too
My problem is that I needed a clamp to hold down the motor in place
as you can see theres only two screws In there and I believe screws for the gears
And that plastic doesnt even sit right against the gear
who ever designed this stupid thing deserves a boot from behind
Glue that thing infront of a heavy motor then that motor will vibrate like a wild bronco
CyberBOB
« Reply #238 on: July 06, 2014, 08:35:28 pm »
What about something like this?  The screws that hold the gearbox on will have to be replaced with longer screws, and spacers added between the mount/gearbox, where the screws pass through.
I know some people use a hose clamp on a bracket as well.  I can't find a good picture of one, but something like this, only hose clamps instead of wire ties.
I've never used a geared unit before, wish I could be of more help.
seathug
« Reply #239 on: July 06, 2014, 09:19:06 pm »
Something like that would be great
Something I can screw on there
I think the hose claml would be to small
This is a big motor
I think I really need to make my own
CyberBOB
« Reply #240 on: July 06, 2014, 09:45:31 pm »
Check this one out.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,27184.msg267281.html#msg267281
Perhaps CGAux26 could be of assistance.
seathug
« Reply #241 on: July 06, 2014, 11:31:25 pm »
Cool
I like how he did his motor mount
I finally figured how the plastic aligned with the motor
now it fits perfectly against the gear
still dont like the idea of gluing it to the gear cover
seathug
« Reply #242 on: July 07, 2014, 04:29:28 am »
Gluing on the driveshaft finally
Everything is aligned so its good to go
all jbweld in place
that kortnozzle is over kill but thats ok hahahha
While thinking if ill use Fiberglass for the motor mount or ply
inertia
« Reply #243 on: July 07, 2014, 08:26:10 am »
Swap over the two props. The starboard (RH) prop should rotate clockwise going forward and the port one (LH) counterclockwise - both viewed from the rear. Some refer to this as "turning outwards from the top". At the moment yours are turning inward.
seathug
« Reply #244 on: July 07, 2014, 08:32:33 am »
Hi inertia
Thanx for telling me
If im not mistaken
I have read somewhere that it doesnt really matter
I guess they were wrong
Ill switch it tomorrow
I think I just ruined my nee portholes <:(
I was trying to glue those plastic on top the portholes
Instead of just pushing it in place I hope I still can removed the glue when it dries out
Maybe I can just peel it off
inertia
« Reply #245 on: July 07, 2014, 08:53:47 am »
Convention is that outward turning props are used for best maneuverability (tugs) while inward turning props are best for speed (warships).
I've never used those portholes but I've always understood that you push the transparent parts into the brass rings and then give them a very thin wash of clear varnish inside, which seeps into the very tiny gap all round by capillary action and makes them water-tight.
GAZOU
« Reply #246 on: July 07, 2014, 08:57:34 am »
My father often said me:
" Work with your head you will work less with your hands "
He was right, it avoids many errors   O0
seathug
« Reply #247 on: July 07, 2014, 09:03:25 am »
Yup you just push it in
I think itll work out just fine since the glue is clear
Ahhh varnish cool
I was thingking of gluing it from the inside lol
seathug
« Reply #248 on: July 07, 2014, 09:04:38 am »
I agree
The problem I have is patience I think
GAZOU
« Reply #249 on: July 07, 2014, 11:02:13 am »
Yes the model making is a school of the patience
If you are well valid you do not begin again
And you ended before the one who made three times bad
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16   Go Up
Page created in 0.097 seconds with 22 queries.
