Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16   Go Down
Author Topic: Aziz - Hawaii build  (Read 106581 times)
seathug
Re: Aziz - Hawaii build
« Reply #275 on: July 15, 2014, 08:37:21 am »
Final motor mount :-))
I didnt like the looks of the first motor mount
Bulky and might heat up the motor
Smaller motor mount
More ventilation :}
Now the jigs for the gearings
I have plan for that one
Ill make it foldable
To removed the couplers
Just fold it down {-)
inertia
« Reply #276 on: July 15, 2014, 08:54:49 am »
Hi dave
Ohh I have seen your removable rudder
which I think its smart thing to do :-))
Im still looking for  wheel collars that is a bit longer than the regular one
Why bother? The idea in the sketch actually works. If you want a "belt-and-braces" solution then just fit collets at the top and the bottom of the rudder. The bit in the middle does nothing.
DM
seathug
« Reply #277 on: July 15, 2014, 09:04:20 am »
I might just do that but we will see
Still need to order that wheel collars
I tried calling all hobby stores on this island
No such luck
I found similar to that wheelcollars at lowes
I might just use that one hopefully itll be the same size
inertia
« Reply #278 on: July 15, 2014, 11:07:48 am »
I've sorted some out for you. Will take a couple of days to get here then maybe a week to get there. SL091R 8SWG Brass Wheel Collets x 4 http://www.slecuk.com/catalogue/Wheels-and-Collets.html
Assemble two collets and the rudder onto the shaft prior to glueing. Remember to grease the shafts and the set-screws slightly before you get your JBWeld out, and roughen the outsides of the brass with a file to provide a good key for the epoxy. Remove the screws and shaft before the epoxy sets up hard, then grind/file the collets to flair in with the shape of the rudder blade. Make sure the screws are on the outer side of the rudder for easy access, not pointing forward towards the prop!
DM
seathug
« Reply #279 on: July 15, 2014, 05:49:57 pm »
DM
Aww gee dave
Thank you
How much do I owe you
Its so hard to find anything on this island
And like I said at the begining of this thread
If you just relying on them for parts
They will sell you anything you need it or not
Anything for the buck
If they have a chance they will sell their inlaws to you  {-)
inertia
« Reply #280 on: July 15, 2014, 08:15:08 pm »
You might yet need some other stuff from over here so we'll leave the book open for the time being, if that's OK? I don't charge interest and you can keep your in-laws, thanks!
DM
seathug
« Reply #281 on: July 15, 2014, 10:10:50 pm »
 {-) glad to know I can keep my inlaw lol
Ok shoots dave
And thanx
Just let me know when
If its ok can we do it again in paypal
Much easier that way hehehh :-))
seathug
« Reply #282 on: July 16, 2014, 08:15:03 pm »
Crazy idea that might just work
boat water leveler :-))
Some used dye to marked it hmmmmm I dont like that idea
since you have to ballast the boat to get it level correctly
if your ballast is to heavy
Then you have marked the boat to high
Some use tape idont like it either
That to much hassle for me
Tape it remove it re tape it nope dont like it
So I came up with the idea
Lay down the boat on a leve surface like your table
just make sure the boat is level
Get a block
Drill it right through
insert a pencil
Aligned that pencil to your boat water level
And slide it around your boat
Marking it all around
dont mind my drawing
Im no Picasso {-)
Liverbudgie2
« Reply #283 on: July 16, 2014, 09:03:34 pm »
Got it in one!
or you could fill the bath, if you have one, and after marking the waterline from the drawing at various points with a pencil place model in said bath and then ballast and trim the model so that it sits at the marked points, remove the model from the water and then cover the surface of the water with talcum powder; then carefully put the model back in the water. Carefully remove the model from the water and allow to dry, you will then have a nice waterline which can be marked  with a pencil again - no I thought not.
LB
NFMike
    • Plague Marine Services
« Reply #284 on: July 16, 2014, 09:34:08 pm »
Pencil method is pretty easy on the Aziz hull as it's basically flat bottomed with the w/l parallel to the bottom.
Things with curvy bottoms  ;D  and angled keels are much trickier.
seathug
« Reply #285 on: July 16, 2014, 11:09:30 pm »
Im just glad itll work with the aziz
Less to worry about
Sigh im going crazy with this build
Its all I can think about
How often do you guys work  on your boats
I look at my aziz build every freakin single day
With a big sign that says
NO TOUCH NO BELONG {-)
seathug
« Reply #286 on: July 17, 2014, 01:43:12 am »
Anybody know where I can get this type of boat
Or atleast the hull
I found one in Philippines but darn shipping is ridiculous
seathug
« Reply #287 on: July 17, 2014, 06:36:05 am »
Gearing jig or what ever this thing is called
much better than gluing it to the motor gears
I can fold  down if I want to remove the couplings :}
seathug
« Reply #288 on: July 19, 2014, 12:59:48 am »
Ok im ready to install motor mounts gearing jigs
Im thinking of going ahead and install those portholes
Then work on my deck beams
Need to cut those fiberglass to size with the deck
seathug
« Reply #289 on: July 19, 2014, 08:10:00 am »
Motor mount and gearing jigs installed
I didnt get a chance to install the portholes
maybe tomorrow
seathug
« Reply #290 on: July 21, 2014, 06:07:57 am »
im using 9mm portholes
I didnt like the 6mm that came with the kit
I used 3m marine glue for the motor mount
Caution the vibration from the motor
Also used that glue on the clamp
So those clamp is not touching the motor
So guys whats next?
I really dont have any clue whats next on this build
The beams maybe? {-)
« Reply #291 on: July 21, 2014, 10:57:42 am »
i would consider the base floor which will hold the electrics. You can then plan out the positions and access from above in relation to the openings in the deck.
Told you it was great fun.   :}
ken
seathug
« Reply #292 on: July 21, 2014, 05:39:24 pm »
Hi ken
Yup it sure is fun now building this kit
You were right the  first fittings are hard on this aziz
If only they have a better place for those running gears
Ok so I need a base plates for all the electronics
I believe you position your electronics somwhere in between the back and the front of the hull
I guess I need to laydown the deck and see where I can get easy access to it
seathug
« Reply #293 on: July 21, 2014, 05:48:49 pm »
Base floor?
Hmmm ill use a thin ply glued to the bottom of the hull?
This  base floor what is it for?
Im thinking of gluing a ply to carry all of those actions electronics
So it will not be sitting down the hull
seathug
« Reply #294 on: July 21, 2014, 06:00:09 pm »
Ok the plan for the actions electronics
that wood block can slide out for easy access
and can slide in under the deck
And ofcourse it comes with a lock to hold it in place
So it  will not be sliding all over the place
this is what my portholes will look like at night
 :-)) reason why I wanted it a bit bigger
For the structure I  want to use oval portholes O0
seathug
« Reply #295 on: July 22, 2014, 05:12:07 am »
Im really lost with my build
I dont have any clue whats next
« Reply #296 on: July 22, 2014, 06:10:41 am »
st......
1. you must stand back from your project build for a few moments   :o
2. get a pen & paper
3. make a list of all of the steps or build achievement's you wish to achieve...... ok2
4. naturally some of these steps will need to follow the/a previous step  O0
5. remember you are the owner of the shipyard where your AZIZ is being built  {:-{
6. you single handily are responsible for the ....built on time ....built on cost plan of your project
7. go back & re-read the build threads of other members builds of this same vessel
Come back in 48 hours [or one week if needed] with your plan  ;D .......members will try & assist  :-)) if you show that you have seriously considered your plan...........
seathug
« Reply #297 on: July 22, 2014, 07:18:46 am »
 {-) ok you got me there ill take your advice and read and read aziz blogs build etc.
its just that I dont want to missteps
I want to build it from the ground up
Know what I mean?
inertia
« Reply #298 on: July 22, 2014, 08:16:09 am »
When all else fails and you really find yourself stuck up a well-known creek without a paddle, remember those four important letters
R T F M:
Read
The
Flaming
Manual
You'll find the deck beams come next and, incidentally, I've no idea why you want to use fibreglass replacements. The 1.5mm I-beams are very strong, easy to make and shape and they're there only to support a 1.5mm deck and cast white-metal fittings - not full-scale containers or winches. Once the beams are in then you''l have a much better guide as to where the radio, battery etc can be fitted.
Your collets should be with you any day now.
DM
seathug
« Reply #299 on: July 22, 2014, 08:57:26 am »
Hi dave
I dont know i think those beams are flimsy
And the fiberglass is hard I can actually carry heavy things on the cargo bay
Ok honestly much easier for me if ill use these fiberglass
Ill work on my deck beams tomorrow
I guess after that all electronics
oh and thanx for those collets :-)
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16   Go Up
Page created in 0.107 seconds with 21 queries.
