April 25, 2024, 10:20:27 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 25, 26
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Wood Care:
info me again sorry
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: info me again sorry (Read 2658 times)
spike
Full Mayhemer
Offline
Model Boat Mayhem is Great!
ely camb,s
info me again sorry
on:
November 10, 2013, 08:30:59 pm »
can someone tell me how to find the center of round dowling please i have tryed and justed can.t
Full Mayhemer
Offline
Newport. S Wales
Re: info me again sorry
Reply #1 on:
November 10, 2013, 08:37:00 pm »
If you use a right angled square with a piece taped on at 45 degrees resting against the circumference of the doweling then the lines drawn across will bisect the centre line....................... hopefully.
Ken
Despite the high cost of living .......... It remains popular
Pondweed
Full Mayhemer
Offline
Model Boat Mayhem Forum is Great!
Reply #2 on:
November 11, 2013, 09:08:02 am »
Put it in a drill and put a blade or cutting edge to it if you hold it firmly, you'll get an idea of the centre.
Another way: say you have 10mm dowel. If you get a 5mm piece of wood, lay the wood flat and then hold the dowel to the side of the wood, then draw alog the top of the wood to mark the dowel. Spin dowel and put 3 lines across the end of the dowel. They should intersect the centre.
david48
Full Mayhemer
Offline
Strathdon,Aberdeenshire
Reply #3 on:
November 11, 2013, 11:58:25 am »
There is a purpose made tool for this job do the Google thing it could throw up Axminster tools ,also just draw the required circle dia with a pair of compasses you will then have all the info to find the Centre,then transfer them to the work piece .There is another way use a right angle square and a 45deg set square set it up so the 45deg by sects the right angle .these all worked for me .Ahh I see Tug Kenny has beaten me to last way I tried to show.
David
Two heads are better than one sheep head as my old plant manager used to say
Full Mayhemer
Offline
near Fleetwood
Reply #4 on:
November 12, 2013, 09:24:02 am »
pondweed
has the exact answer, quick accurate and no cost what so ever.
only addition I can make is, for accuracy, use a craft knife to make the marks rather than a pencil.........much thinner lines, giving greater pinpointed marks.
neil.
Print
Pages: [
1
Go Up
« previous
next »
Wood Care:
info me again sorry
