Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 196598 times)
nivapilot
  • re-invented rc boater
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #150 on: June 20, 2016, 08:51:14 am »
Seems a crying shame to put a deck on that, and hide all that beautiful woodwork.
Perspex deck??
missyd
« Reply #151 on: June 21, 2016, 09:57:11 am »
Thanks a lot to you two!!!! No I will cover up everything with a deck and a lot of color.... %)
More work done for the anchors ...
Danielle
missyd
« Reply #152 on: June 23, 2016, 06:10:42 pm »
Closing the space for the anchors again  ok2
Fits nicely ....
And some hullprotection at the back ....
Danielle
« Reply #153 on: June 23, 2016, 11:03:52 pm »
I see the benefits of your stout frames Danielle as they make the structure strong even when cutting holes in the sides. There is less risk of planks pinging out of place.
Tidy carpentry :-))
missyd
« Reply #154 on: June 24, 2016, 09:50:31 am »
Tidy carpentry :-))
Thanks a lot .... you're right the hull is bomb proof!!!  :}
Some more work done this morning ...
Work done yesterday ...
Danielle
missyd
« Reply #155 on: June 25, 2016, 08:19:14 pm »
Spent another hour in the workshop yesterday evening ...
And today after a long biketour I managed to do another hour of work.
Danielle
missyd
« Reply #156 on: June 27, 2016, 02:42:49 pm »
Finished some more work ...
Hull partly treatet with filler ....
... and with primer...
This part is finihed!
Hull finished with filler ....
Danielle
« Reply #157 on: June 27, 2016, 08:08:00 pm »
Wonderful! It is really starting to come together. I like the rubbing strips.
missyd
« Reply #158 on: June 30, 2016, 05:13:38 pm »
I like them too ... brings the model to live!
After filler and primer I painted the lower part of the hull red ....
Danielle
« Reply #159 on: June 30, 2016, 08:32:39 pm »
Now your cooking on gas Danielle. Looking great.
nivapilot
« Reply #160 on: July 01, 2016, 06:49:31 am »
I love it when paint starts going on.........makes it more a "boat".... :-))
missyd
« Reply #161 on: July 01, 2016, 05:54:02 pm »
Thanks a lot you two. With color on the hull you can see the lovely curves much better!  ok2
Launching of the boat. Couldn't resist today ... time to get the hull into water.
With 7-8kg lead inside it floats very goodd and stable.
I will post a short video later....
Danielle
missyd
« Reply #162 on: July 01, 2016, 06:09:38 pm »
Danielle
« Reply #163 on: July 01, 2016, 06:23:29 pm »
Looking good in the water Danielle  :-))
jarvo
  • Etherow model boat club
« Reply #164 on: July 02, 2016, 09:10:32 am »
Onwards and up to the deck and superstructure, sooooo good
Tugs are for pulling
missyd
« Reply #165 on: July 03, 2016, 07:00:33 am »
Thanks a lot you two!!!  :-))
Some pictures in daylight ... I like the red a lot ... its Flame Red RAL3000 mixed with a little bit of Gentian Blue RAL5010. Inside of the hulle is painted with Oyster White RAL1013.
Danielle
missyd
« Reply #166 on: July 03, 2016, 07:04:11 am »
Bad news .... in cold water and cold weather less than 15°C (its cold at the moment outside) the hull changes a lot .... the planks started to get longer and wider. In warm conditions the hull turns back to normal. I think in the future the paint will crack and water goes into the planks. Any ideas how I can safe the hull?
Danielle
« Reply #167 on: July 03, 2016, 08:30:00 am »
Danielle
Clearly the images of the hull in the [bath] water show that the inner surfaces are unpainted
The air temperature of 15 degrees C is the ambient, the water would have been the same temperature
If the outer RED paint was cured sufficiently would suggest that moisture had entered the wood from the inside
Natural moisture content of wood is in the order of 12%....however you now appear to have sealed the internal hull surfaces
If this is the case, you may need to sand & remove the outer hull paint and let the wood return to it's natural moisture state prior to any further painting
It may also pay dividends to apply a Z-Poxy or polyurethane type surface to fully waterproof the internals prior to any further work
jarvo
« Reply #168 on: July 03, 2016, 08:59:16 am »
Hi Danielle, i concure with Derek, also allow about a week for the wood to dry, if you can in the lounge so there is some warmth without much moisture in the air. When dried out seal the inside of the hull with Layup resin, or Zpoxy but this is expensive, this is quile thin apply between the ribs and roll the hull to coat all the internal structure, including the ribs themselves, the wood should absorb some of the resin if it is thin enough, when it has set (24 hours ish) coat the outer hull with model aircraft light weight glass cloth, again with the resin and a couple of coats to get a smooth finish, remember most paint these days is not waterproof, the resin will seal the wood and give you a smooth sanded surface to apply the finishing colour. If you need contact emails for the Glass Cloth i can send details of suppliers who do mail order.
Mark
missyd
« Reply #169 on: July 04, 2016, 05:17:29 am »
Thanks a lot for the informations ... I will sand the hull today and then think about what I will do next. Haven't decided yet. I hate epoxy/polyethrane and any nasty smelling things because I am allergic to it....
Danielle
jarvo
« Reply #170 on: July 04, 2016, 01:57:47 pm »
No worries Danielle, lay up or Zpoxy dont smell too bad but you do need good ventilation, have you tried a good mask? i use a 3m mask with particle filters
Mark
missyd
« Reply #171 on: July 04, 2016, 05:11:33 pm »
I never used masks sofar .... I will give a try in sanding the hull and paint it new. The inside was painted saturday. Maybe it will be ok. If not I'll do something else.
Sanded everything to a smooth surface and gave it a new thin coat of paint afterwards... the whit patches show the problem zones ... much less as I thought.
Danielle
jarvo
« Reply #172 on: July 04, 2016, 08:40:22 pm »
Keep your fingers crossed
Mark
hama
« Reply #173 on: July 05, 2016, 10:18:44 pm »
There is a product called Eze-kote, waterbased 1-part epoxy substitute. Perhaps someone here have tried it? I haven't but would like to.
Just a thought.
Hama
Vts99
  • Clydebuilt = best built
« Reply #174 on: July 05, 2016, 11:30:38 pm »
I've just put eze Kote on my fairmount hull with a layer of cloth . It's have it a glass like finish but haven't painted hull yet or tried it in water but been told it's same result as epoxy
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... 28   Go Up
