Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 196188 times)
jarvo
  • Etherow model boat club
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #225 on: August 31, 2016, 09:41:44 pm »
The closeup photo makes the deck look even better, superb work
Mark
Tugs are for pulling
missyd
« Reply #226 on: September 01, 2016, 06:35:18 pm »
Thanks you very much Mark  :-))
Now its time to finish the bow .... !
I have to say that with the extension on the bow the hull is starting to look like the Nuova Loredana!!!
Used paper to make  it and will use very thin and flexible plywood to fabricate it.
Danielle
Unsinkable 2
« Reply #227 on: September 02, 2016, 08:06:21 am »
Coming along fantastically, I really enjoy watching your builds. Well done. U2
missyd
« Reply #228 on: September 02, 2016, 06:01:32 pm »
Thanks a lot!!!  :-))
Bow came out as wished!!! 2x 0.4mm birchplywood .... another one will be added later. Wonderful material to work with. Bends very easy!
Danielle
missyd
« Reply #229 on: September 05, 2016, 04:19:52 pm »
More work done ....  ok2
Danielle
missyd
« Reply #230 on: September 08, 2016, 04:36:17 pm »
More work done on the bow ...
Danielle
« Reply #231 on: September 08, 2016, 10:52:51 pm »
Thats better. You must be pleased at how well that bow has faired in.
missyd
« Reply #232 on: September 09, 2016, 03:14:26 pm »
Yes I am ... I wasn't sure about the result but it cme out OK.
More work done today ...
Danielle
« Reply #233 on: September 09, 2016, 09:57:01 pm »
I can see now just how much work has gone into producing the flared bow - a beautiful job, well done. :-))
« Reply #234 on: September 11, 2016, 06:16:59 pm »
Too right  :-)) On a non related subject for curiosity sake. In the UK we have a supermarket chain called the 'Cooperative' and I see you have some boxes with 'COOP' on them. Do you also have the 'Coop' where you live? I don't want to be nosey about the boxes content as that is your business.
Lovely work Danielle.
missyd
« Reply #235 on: September 11, 2016, 10:08:18 pm »
Thanks a lot! Always doing my best to keep you updated with pics!!!!
Coop isn't the same as Cooperative in the UK. They have no buisness relations together. Coop is one of the two food and DoItYourself giants ins Switzerland ....
Danielle
missyd
« Reply #236 on: September 12, 2016, 05:54:22 pm »
New week ... same work and Project.
Danielle
Big Ada
« Reply #237 on: September 12, 2016, 05:59:15 pm »
Hi Danielle
With a boat has big as yours and the weight . You might fine you are not moving enough water to turn the boat .  Have a look in non modelling areas. You can get Caravan fresh water pump 12v that will shift 5L per min.
Your in take might all so be restrictive . One option might be X2 pumps . they suck water in from under the flat of the hull near the keel and exit via the bow thruster  .X1 for port X1 for starboard .
http://www.ebay.co.uk/itm/like/361554236766?lpid=122&chn=ps&googleloc=1006976&poi=&campaignid=207297426&device=c&adgroupid=13585920426&rlsatarget=aud-133395220626%3Apla-156022122546&adtype=pla&crdt=0
https://plus.google.com/photos/105202506859524458881/albums/5117538442090596849?banner=pwa
Sorry to but in on this great build but I have a 19 foot long Bulk Carrier and my home made bow Thruster broke at the weekend and I am now thinking about replacing with 1 or 2 pumps, I have found these, http://www.ebay.co.uk/itm/DC-12V-Electric-Solar-Brushless-Motor-Water-Pump-Aquarium-Fountain-1000L-H-New-/291408615748  what are your thoughts please, they give 160lts per minute?. Again, sorry to but in.
Len.
missyd
« Reply #238 on: September 12, 2016, 06:53:32 pm »
Powerful pump! But it works only in one way I think. Might work well but I have no experience with bow trusters.
I must admit that I wouldn't use the pump bow truster again. To complicated to build. I wish I hadn't built this feature in my ship.
Danielle
jarvo
« Reply #239 on: September 12, 2016, 10:20:39 pm »
Very powerfull pump, you could use 2 one to port and one to starboard, with such a big model you would have plenty of space for the plumbing
Mark
« Reply #240 on: September 12, 2016, 11:25:17 pm »
Len.....~~16 litres per minute ...not 160 %) ..... Derek
missyd
« Reply #241 on: September 13, 2016, 04:51:42 pm »
Started with the second part of the deck ... only to stop again and doing something else ...  %)
... did all the "steel" bracing on the bow.
Danielle
Big Ada
« Reply #242 on: September 13, 2016, 06:18:28 pm »
Oops, well spotted.
Mark
That was what I was thinking of doing.
« Reply #243 on: September 13, 2016, 07:52:08 pm »
You've done lovely work on those braces Danielle! Not one wrong angle seen  :-))
jarvo
« Reply #244 on: September 13, 2016, 09:22:13 pm »
Hi Danielle, in the second photo there is a blue line between the deck and the bow, is this a sealer or just a glue line???
Mark
« Reply #245 on: September 13, 2016, 11:20:51 pm »
...and I like the way you have incorporated the wires into the forward central bracing - very neat. :-)
missyd
« Reply #246 on: September 14, 2016, 05:24:19 am »
Thanks a lot to you all!  :-))
The wires are incorporated the same on the original ....  ok2
The blue line is from the pen I used to mark the plywood. I used no sealer. I always use simple fast bonding white wood glue.
Danielle
jarvo
« Reply #247 on: September 14, 2016, 11:01:18 am »
Simple when you know the answer!!!! the build is well up to your superb standards
Mark
missyd
« Reply #248 on: September 14, 2016, 08:41:58 pm »
Thanks a lot Mark!
 <:( <:( my Dremel 3100 drill decided to quit working ... R.I.P.
I may buy a Proxxon 230V drill ... I think they have the better quality.
I could finish the work with the help from another Dremel 3100 I had in stock.
Its always tricky to get the holes on the right place and dril it out to the right shape ...
Danielle
« Reply #249 on: September 14, 2016, 09:28:11 pm »
I have always found making ovoid openings tidy to be one of the most difficult tasks. Yours look very tidy  :-)) Sorry to hear of your loss Danielle, an old reliable tool becomes an irreplacable friend. You know what it can do and how to get the best out of it. The crud in the grips is testament to many hours of use making and creating with it.
I have a triangular needle file bought in what was then (1990) a cheap set at about a tenner and I broke the tip off, but only a little, leaving what became my favourite line scribing tool. If I or anyone breaks that, I will go stark mental as I cannot get another like it:O( Everyone sells ones that have a noticable drop to the tip whereas my old one has a continuous gentle slope to the end:O)
Sorry, back to the M/P Nuova Loredana.
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 28   Go Up
Page created in 0.104 seconds with 22 queries.
