Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 195627 times)
missyd
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #525 on: April 06, 2017, 04:40:30 am »
Thanks a lot! :-))
I painted the matte clear tubes inside .... we'll see how it look today  ok2
Danielle
RAAArtyGunner
« Reply #526 on: April 06, 2017, 05:19:36 am »
Are the tubes clear plastic ?
...if so, you could try inserting painted paper or maybe shiny plastic inside the tubes. That way, the outside of the tubes would give the impression of "glass" lenses. :-)
Good tip  :-))
missyd
« Reply #527 on: April 06, 2017, 12:01:21 pm »
Well today I made the builders plates .... all done on word and printed on paper.
Gave the lights some sort of shape ....
Looks ok to me ... the size is alright.
And more details to them ...
Finished the red and green lamps .... they are not as I wanted .... never mind .... I glued them to the mast.
No they are not OK. First: The lamp to the lower right should be white! Second: The size is not alright.
2-3mm less in height and 2-3mm more in diameter. Off I go to redo them!!!
Danielle
missyd
« Reply #528 on: April 07, 2017, 12:04:52 pm »
I scrapped the red and green light today and made new ones out of a 8mm acryl rod I bought a few weeks ago.
First I made notes about the size ...
Milling down to 6.5mm on my lathe. Anything on a lathe or drill has to be made with a very low RPM or the acrylic rod will melt.....
Marking where the material should stay ...
Milling the contours and drilling a 3.5mm hole for a LED or microbulb.
With a small handsaw I cut away the finished position light.
And here is the finished positon light. A little bit of black color and its ready to be used on the boat.
Danielle
missyd
« Reply #529 on: April 10, 2017, 02:28:32 pm »
New week still the same model to finish ....  {-)
Lenses got some color ....
The airbrush color from Schmicke can also used with a brush or soft tip pen.
Tamiya chrome color for the reflectors of the spotlights.
Position lights needed a black top...
And later black feet .... spotlights got their casings blackened.
Danielle
« Reply #530 on: April 10, 2017, 09:09:41 pm »
I like the smell of acrylic when machining it  %% Lovely job on those position lights and also on the bigger ones Danielle, they look very accurate.
missyd
« Reply #531 on: April 11, 2017, 04:11:41 pm »
Thanks a lot!!!!  :-)) :-)) :-))
Made a round base for every position lamp ....
LEDs for all spotlights ....
Wired, soldered and glued in place ....
Danielle
jarvo
  • Etherow model boat club
« Reply #532 on: April 11, 2017, 09:30:43 pm »
NIcely done, they really look the part
Mark
Tugs are for pulling
Paul2407
« Reply #533 on: April 13, 2017, 09:12:38 pm »
I've just spent the last 3.1/2 hours reading through all 22 pages of this and the level of detail and quality of your work are 2nd to none, keep up the great work missyd  :-)) I wished I had 1/50th of the skills you have
FrozenRabbit471
  • Long may you big jib draw
    • My Instagram
« Reply #534 on: April 17, 2017, 01:16:42 am »
Hi all,
I was just referred here by a chap answering my call on stabiliser arms and such. I'm going to do my first boat build soon. It's looking like the Nordkap, I am favoring the Smit Nederland Tug though.
I was asking where I might find the stabilisers online because I love the look of them. I'm not sure they would look good on a Tug. lol
But I think you have answered my question. Bravo.... great job.
Better to have it and not want it, than to need it and not have it
FrozenRabbit471
    • My Instagram
« Reply #535 on: April 17, 2017, 02:11:01 am »
Hi, What's the trick after you print them? do you simply put them where you want them and apply a coating?
missyd
« Reply #536 on: April 20, 2017, 04:29:32 pm »
The stabilizers are made of wood and are very sturdy as the hull is also made of wood.
I'm back again ... I needed a break from building the Loredana. I bought a Rock Crawler RC-Car to play with outside. I had to adapt a Jepp Wrangler bodywork to a chassis .... lots of fun I had.
Today I finished all electrics at the back. All 4 spotlights and the position light are ready for use.
Danielle
kees de mol
  • crazy about shipbuilding
« Reply #537 on: April 20, 2017, 08:38:41 pm »
stunning
Groetjes, Kees
FrozenRabbit471
    • My Instagram
« Reply #538 on: April 20, 2017, 08:40:29 pm »
will there be refreshments on the top deck when she's put out to sea? %%
« Reply #539 on: April 20, 2017, 10:42:42 pm »
It's great to see you back at it Danielle. I am sure the  break did you and your enthusiasm wonders. Your standards are as high as ever  :-)
RAAArtyGunner
« Reply #540 on: April 20, 2017, 11:19:42 pm »
I'm back again ... I needed a break from building the Loredana. I bought a Rock Crawler RC-Car to play with outside. I had to adapt a Jeep Wrangler bodywork to a chassis .... lots of fun I had.
You could post that in the other hobbies section on here.
Cars and truck trailers are also featured. O0 O0
missyd
« Reply #541 on: April 21, 2017, 02:31:07 pm »
I made a posting in the Cars and Trucks section ....  ok2
Danielle
missyd
« Reply #542 on: April 21, 2017, 02:47:30 pm »
I had to paint the gantry white even if it was white .... not all ABS profiles have the same white .... so I painted it today. I also glued all wires with paint to the gantry.
Danielle
« Reply #543 on: April 21, 2017, 04:12:59 pm »
It's a good idea to paint white plastic, even white, as plastic can yellow over time. As i found to my cost.  <:(
RAAArtyGunner
« Reply #544 on: April 22, 2017, 12:28:56 am »
Yes, saw it and is well presented, has had quite a few views  :-))
RAAArtyGunner
« Reply #545 on: April 22, 2017, 12:31:16 am »
And will yellow very patchy in places but not uniformly. <*< <*<
missyd
« Reply #546 on: May 02, 2017, 10:11:38 am »
Back at work!!!! Received my Jeep TJ Rubicon in 1/1 scale after Easter and had to play and drive it quite a lot!  :}
First I made space in my workplace. Couldn't move around anymore ....
Position lamp ready ....
Green and red lamp on the deck house glued in place ...
Wiring for the radar motors is ready ....
I really hope everything will work! I do not like making the electric part of the boats and I never try it out till everything is finished. I there is a fault in the wiring there is no chance to redo anything ....
Danielle
jarvo
« Reply #547 on: May 02, 2017, 10:52:26 am »
Hi Danielle, have you a picture of the radar motors before you fitted them? allowing of scale they look very small and in the mast arms look very good
Mark
missyd
« Reply #548 on: May 02, 2017, 04:15:35 pm »
Sadly I do not have pictures ... but I have the link where I bought them. Diameter is 6mm length is 30mm with axle I think ....
(sorry german webshop)
http://www.conrad.ch/ce/de/product/248782/Micro-Motor-G-700-G700-40-Umin-5?queryFromSuggest=true
And here the link for the datasheet as a PDF file...
http://www.produktinfo.conrad.com/datenblaetter/225000-249999/248782-da-01-de-MIKRO_GETRIEBEMOTOR_G700.pdf
These motors run very well at 1.5V for radars. If running faster they will get noisy and nasty in terms of sound ....
Danielle
« Reply #549 on: May 02, 2017, 09:15:10 pm »
I am impressed at how clear you got your bench Danielle. They rarely stay that way for more than a few days I find. I look forward to seeing those radar units rotating. I am sure it will all work perfectly.
Pages: 1 ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28   Go Up
Page created in 0.148 seconds with 21 queries.
