My take on Float chambers and carbies.
The object of the exersize is to maintain a constant flow of fuel to the carby, equiped in this case with a spray bar, regulated by a needle valve.
To do this, we require a constant flow of fuel at constant pressure, at a given rpm.
with a float chamber we can maintain a constant head of fuel as applied to the spray bar.
Without this, and only a free to air vented fuel tank, the head varies as the fuel level drops, and any level below the spray bar will not flow under gravity to the spray bar, therefore the whole of the tank should be above this level, resulting in a large flow reducing to zero.
To get around this, we pressurize the fuel tank, enabling the tank to be mainly below the spray bar, as the pressure pushes the fuel out of the tank, upto the carbie.
Using the pressurized system, the flow to the spray bar
- if above will be pressure plus a head factor due to gravity trying to push the fuel out of the tank.
- if below will be pressure less a head factor due to gravity trying to keep the fuel in the tank.
Only the header tank supplies a constant head of fuel.
That's my take - right or wrong.
cheers
