Pages: 1 [2] 3 4   Go Down
Author Topic: Dumas U S S Whitehall  (Read 30367 times)
Harquebus
Re: Dumas U S S Whitehall
« Reply #25 on: April 02, 2015, 09:59:33 pm »
Maybe you are correct with the 3-blade props. The Admirable class and the PCE are so similar one is lead to think they're identical under the waterline...  The USS Rexberg PCE(R)-855 shows 3-blade props in drydock photos. :-X
Photo's failed
ken
~Harq
Stan
« Reply #26 on: April 02, 2015, 10:29:25 pm »
Hi no pictures.
Harquebus
« Reply #27 on: April 04, 2015, 12:35:27 am »
I see them just fine. Why is that? I do want to know.  {:-{
See here: http://www.navsource.org/archives/12/02855.htm and scroll down for the drydock photos.  ;)
Here's the pics I was referring to: http://www.navsource.org/archives/12/120285508.jpg
http://www.navsource.org/archives/12/120285510.jpg
~Harq
RAAArtyGunner
« Reply #28 on: April 04, 2015, 01:03:57 am »
All that shows in the previous post is a small square with black cross where there should be a picture usually happens when you don't up load the photo from your PC but refer to a web photo host.
In other words we all don't have the same access to your reference whereas if you upload your photo from your PC it is there for all to see.
There has been much commentary about using photo hosts and which ones etc but at the end of the day they all fail. Because if you move or cancel you photo storing etc all photos are lost to that thread. And as a photo is worth a thousand words lots of discussion is missing on the forum accordingly.
Harquebus
« Reply #29 on: April 04, 2015, 05:19:11 am »
I can no longer edit my post (how dumb is that?) so now I will post again just to rectify the photo content for posterity and because I myself dislike following an off-forum photo link. The pics weren't remote-hosted by me using photobucket or some such; only that they were located on navsource.org. In other forums this is not an issue because the photo site is usually quite stable as a web resource. ....So in the future, when posting I will disregard the photo button in the options bar and will use the attachment function instead.
Once again:
"Maybe you are correct with the 3-blade props. The Admirable class and the PCE are so similar one is lead to think they're identical under the waterline...  The USS Rexberg PCE(R)-855 shows 3-blade props in drydock photos."
~Harq
RAAArtyGunner
« Reply #30 on: April 04, 2015, 05:25:24 am »
 :-)) :-))  O0 O0 Yes that is all I ever use, and occasionally  re-size the image to the allowable limits
Harquebus
« Reply #31 on: April 04, 2015, 05:36:41 am »
This is the one forum among many I visit that seems to have "issues" with intuitive usage. Guess it ain't all that intuitive or the problem is just me.  O0
Pity too that there's a size limit that is, well, limited. Small to medium pics are sometimes hardly useful at all. Anway, here's that shot I was supposed to show showing the USS Inaugural high and dry on the riverbank. She's got 4-bladed screws:
~Harq
Stan
« Reply #32 on: April 04, 2015, 08:29:10 am »
HI everyone thanks for the comments on the props. Does it matter if you fit 3 bladed or four bladed  props  looking at pictures they carried both.
Stan
Harquebus
« Reply #33 on: April 04, 2015, 06:55:46 pm »
Ultimately no, I think. I'm just trying to find out if there was a historical difference between the two vessel classes in regards to the propulsion design. They look similar and may be the same ship for all intents and purposes but they have very different roles...
I figure maybe the PCE required "speed props" while the Admirable class minesweeper needed better power at lower revs for its mission and role?
The USS Hazard (AM-240) which was originally buried up to the waterline as a museum ship, was refloated by flooding in 2012 and when the waters receded she settled again and exposed most of the hull to include the props which are also 4-blade. Of course this proves nothing so...Pffft! Who knows?  <:(
Anyway, back to your build, sorry for the diversion.
~Harq
Stan
« Reply #34 on: April 07, 2015, 09:03:16 pm »
HI everybody sorry for no new pictures I have been busy with other things. The motors in this model have been removed they did not work very well when connected to the speedo cheap and cheerful. I have now replaced them with 2 MFA Como 140/1 motors and up to press they seem much better pictures to follow later this week.
Stan.
« Reply #35 on: April 08, 2015, 08:43:42 am »
Looking forward to seeing them!
Stan
« Reply #36 on: April 22, 2015, 08:23:30 pm »
Hope be back posting later this week.
Stan.
Stan
« Reply #37 on: April 23, 2015, 08:52:54 pm »
Hi Guys back on the scene once again. I have enclosed some pictures showing final fitting out of the running gear. Motors have been changed to MFA 140 /01 these run up to nine volts. Also included pictures showing balsa frames used to construct the bridge sections. These are very flimsy and I would recommend them to be made from plastic card. The bottom section will need a further 4 mm to give the correct height. More pictures to follow.
Stan.
Kirklees Model Boat Club
« Reply #38 on: April 23, 2015, 11:12:07 pm »
Crikey that must really make some fumes when being laser cut!
Looking complex but good Stan.
Stan
« Reply #39 on: April 24, 2015, 04:17:10 pm »
Just a couple of shots showing plastic card applied to the balsa  frame work. When complete it does make strong construction. I have used super glue for fixing the plastic card to the balsa frame work more pictures to follow.
Stan.
Stan
« Reply #40 on: April 26, 2015, 08:29:28 pm »
The P C E hull had its sea trial this morning and I am pleased to say it sailed with no problems. I hope to have picture later this week.
Stan.
« Reply #41 on: April 27, 2015, 11:46:32 am »
That is good to hear! It means you have some more time to spend on the build rather than having to revisit the problems and sort them out.
Stan
« Reply #42 on: April 30, 2015, 06:58:59 pm »
Picture showing first sea trials of the Whitehall hull. :-)) :-)) :-)) :-)) :-)) :-)) :-))
Stan.
Stan
« Reply #43 on: April 30, 2015, 07:21:44 pm »
Found a better picture Whitehall is visible to the left of the picture.
« Reply #44 on: April 30, 2015, 10:39:25 pm »
Was a fellow boater showing you his Fletcher while you were testing your hull Stan?
Stan
« Reply #45 on: May 13, 2015, 08:07:36 pm »
Just a few shots showing further timber fitted in the bow also plastic tube fitted at anchor points. Final shots  showing some of the superstructure  on the deck more to follow.
Stan
Stan
« Reply #46 on: May 17, 2015, 09:22:51 pm »
One shot showing further bracing fitted on the fantail to give more strength when the rear section is glued down.
Stan.
« Reply #47 on: May 17, 2015, 10:18:17 pm »
I resined my stuffing tubes in today and they look like yours even though the epoxy is clear. I must be doing something right:O)
Looking good:O)
Harquebus
« Reply #48 on: July 23, 2015, 11:11:19 pm »
I'm not sure that's a better picture, Stan. Your Whitehall, to use the vernacular, "photobombed" another's photo of a destroyer... {-)
Anyway, great progress on this kit. There's another build thread on RCG and it was built as-designed with a single screw--the reason given was that there wasn't enough room in the hull for two shafts and motors. But you've done fine with it.
You're a bit noncommittal on your motors, aren't you?  {-)
~Harq
Stan
« Reply #49 on: July 24, 2015, 12:19:33 am »
P/M sent what is RCG.
Stan.
Pages: 1 [2] 3 4   Go Up
Page created in 0.113 seconds with 21 queries.
