I love tinterweb. 6 center drills and (Cos I'm having issues with wandering drills and a little eccentricity) some stub drills arrived this a.m.
So started on the valve wheel.
1)Faced off some 9/16 bar.
2)Turned 5/8" down to 1/2"
3)Center drill (spot only)
4)Drill for 8BA.
5)Tap hole 8BA.
6)Put Knurling tool into tool holder,offered wheels to c/l, wound them down until in contact with work, backed out slide, wound down 1 turn. wound the slide back in until left end of wheels made contact with work 1/8" from end of work. Switched on lathe on slowest speed, put plenty oil about. fed the slide in to c/l. wheels turning OK so fed the knurls up the work slowly until made contact with step, then backed out.
7) switched off and gave the work a wipe and RESULT, my first knurl.
I should add that while I was in the shed a'knurlin', I missed GB(Scotland) win the bronze a'curlin'!!! BZ Ladies!!!!
chamfered end with file.
9) removed top center with boring tool.
10)used parting tool to remove underneath to 3/16".
11) parted off leaving a 1/16" depth boss.
Final job on lathe was to make the separate outlet male union but forgot to take pics.
boiled the body and nozzle in washing up liquid, rinsed, dried fluxed and silver soldered in position. Again forgot to take a pic before I put it in to pickle. Tomorrow, OK?
Jerry.
