Hi Hammer, I can't comment as I have no experience of this kit.
On with the boiler. I has an incident while cleaning up the bench prior to assembly. While running the vacuum cleaner nozzle over the bench I failed to pay attention to what the hose was doing behind me and knocked the boiler shell onto the floor. Result, a slightly deformed rear rim. It wasn't a bad one but it did show it's effects later on. I assembled it all out of the pickle bath, cleaning with wire wool and applying flux as I went. Applied 1mm thick solder rings as required and carefully fluxed over the solder. Wrapped the boiler in insulation matting from bottom to top, securing with copper wire. Put the wrapped boiler in the hearth with the matting tucked underneath and made a hood out of two sheets of insulation. On with the goggles, hat, thick coat and welders gloves, a deep breath and flashed up the torch (1", jet unknown and using butane) and off we go. Kept the nozzle moving and got up to temperature. The flux didn't behave as expected but turned to like dirty slush on the side of the road in winter, however finally it started to clear, everything came clean, a quick look without the torch showed a dull red glow, replaced the flame and then one after the other the small rings melted followed by the firetube ring then the shell ring and the last bit between the firetube bottom and the shell (good heatsink here methinks). Kept the torch moving until sure everthing taken then shut off. See video here,
http://www.youtube.com/watch?v=xYxXb7u45Fg&list=UUbagXHeyf-nZGj-QE8latEQ&feature=share Total time taken 13 minutes. It seemed like an hour and panic would have occurred if I hadn't actually kept my eye on the clock. Removed most of the insulation and let everything cool down, Takes a long time to cool enough to turn over to do other end. When I did I found that the back end flux had run off into the matting, the peeling off of which gave the appearance of a boiler with a violent fungal infection!! It took me a goodly while to clean all that lot off until, praying that the flux had stayed in the joins, I applied more flux, re-seated the rings and repeated the process with similar results. Repositioned for top bushes and finished the job, or so I thought.......
After pickling and cleaning off I found that one return tube on both ends hadn't run into the joint and the tube was loose, the pressure gauge bush on the front plate had soldered but not dropped into the hole when the solder melted and finally the solder on the backplate rim between the rim and the bottom of the fire tube in way of the aforementioned ding had run but was showing no sign of a fillet for 1 ". Apart from this all looked neat and tidy with no excess of solder all over the place. I resoldered the back plate with another ring of solder but there was still a small gap so did it a gain after straightening the left over bits of solder putting them in the gap This time backplate all ok. Re-did the front plate giving the offending bush a little encouragement with my little hammer. Result. I'm pleased. Used 12feet of 1mm Silverflow55 wire, 50gms of flux and best part of 4Kg Gas. Suntan's coming on well though!
Thankyou all for your advice, pictures and encouragement.
Next job, rig up an hydraulic test rig.
Jerry.
