I made 22 silver solder rings by winding the wire tightly around a piece of 3mm rod, keeping the coils tight and running a flame over them until they relaxed and set. Removed the rod and cut the rings off with side cutter. I had two flanges left over and cut two lengths of copper pipe to test easyflo flux against tenacity flux. I boiled all the pieces in detergent, rinsed them, cleaned them with wire wool, applied easy flo to one pair and tenacity to the other pair and put a ring on each pipe by the joints. Heated them up with my small torch. Fluxes behaved as they should, drying out then turning to clear liquid just before the flange turned dull red. The rings melted as the red got brighter and flowed when flange and pipe turned orange. Both fluxes gave the same result, perfect joints with full penetration and a small, neat fillet. So, on small parts at least, easy flow solders copper to stainless steel. Will keep the tenacity flux for something bigger requiring a lot more heat maybe. Set up all the unions and flanges with rings and easyflo flux and soldered the lot in a couple of minutes. Will set up on the cylinders next to solder to the control valve block next.
Jerry.
