My latest findings with this coil:
I bought two small (100g) gas cylinders, and they are too small to run the big engine. It ticks over, just, but its a smaller amount of heat than just one burner connected to a larger tank. Im going to buy bigger tanks next time. Better surface area to volume ratio, and the propane and isobutane dont burn off so soon, just leaving boring butane.
I found the spec on the burners im using. The two burners, with isobutane/propane mix fuel, and large tanks, have a maximum combined output of 5000 watts. So my boiler runs at maximum as a 5kilowatt heater. Bloomin' eck! Thats nearly 7 horsepower of heat!
Id like to try making a more compact version of the coil, possibly in a folded configuration, with 12 feet of tube arranged in figure 8s going side to side and another 12 foot layer above it going front to back. Im a bit more experienced at how to bend coils now, i reckon i can do a much neater, more compact job than i did with this, my first coil.
Seeing as the current test article will run the big triple slowly or the stuart 10 very fast on one burner and a large tank, even with half the coil effectively out of the flames, i reckon its worth a try to see if i can get the whole length heated by one 2.5kW burner. It would also be able to arrange things so the water flows in at the top, and steam out the bottom(counterflow) which isnt really possible on the current single layer design.
If i can make a boiler with 24 feet of kunifer 3/16 pipe that fits into, say, a 4.5 inch diameter steel pot with burner at the bottom and exhaust at the top that would be cool.
Cause then i can make another one. With 1/4 stainless pipe, and its own 2.5 kw burner. And then connect them in series, so id have separate fine control over the main boiler(kunifer) and superheater (steel) sections, which seems like it would be super useful. I have some ss tubing that would be perfect.
And 40 odd feet of pipe would be an interesting experiment, although id need to man up the pumps, which brings us to--->
Ive also upped the pump motor to a mfa como 100:1 unit, its really good and powerful. No more stalling pumps! Im building a duplex pump arrangement with opposed rams on a common driving crank to try and get a more even flow, and also to double the flow rate possible with this motor/gearbox combination.
I am beginning to wear out components with the constant testing, taking apart, modifying, reassembly and re testing, i dont think this particular coil is going to ever get on the water. It will serve as a testbed, at any rate.
Ive also experimented with extra water pumps driven off the engines output shaft. Sucked lots of power out of the engine, and made it slow and surgey. Too much feedback in the system as well as extra load. Terrible idea. I may fit a magnet and tach to the flywheel, and use the resulting control signal (after some processing) to control a smaller 'acceleration pump' powered by another electric motor. Could also wire in a spinning balls speed governor with the lever arm connected to a control potentiometer controlling the same pump to try and control the surging. I have a suitable governor, reckon its worth a try!
Also i reattached the forced lubrication system to be big three cylinder engine. Theres a dashpot, a pump driven from the output shaft (geared down) and some check valves and a bypass valve involved. There is now over six feet of copper 5/32 pipe connecting everything together in the whole system..
Overall, its now resembling a 2 foot by 6 inch by 8 inch miniature oil refinery.
Or possibly a rocket motor.
Wahey!
