Pages: [1] 2 3 4   Go Down
Author Topic: Fishing Trawler Propitious FR927  (Read 26193 times)
kees de mol
  • crazy about shipbuilding
« on: April 27, 2014, 12:04:07 pm »
Hallo everybody
I allready have build a dutch fishingtrawler but since that's finished I was looking for a new project. On an English site trawlerphotos I started looking for a new ship to build.
http://www.trawlerphotos.co.uk/gallery/
Here I soon found a realy special ship. A ten meter trawler with a very odd shape, I never saw a ship like this before.
Port Registry: FRASERBURGH
Name: PROPITIOUS FR 927
Werf: MACDUFF
Buildyear: 2000
Length: 10 meter
Catagory: Near-shore fishing vessel, Small scale coastal <10m
Fraserburgh Schotland
Main Target Species: PRAWNS (garnalen)
Opvarenden: max 3
Kind regards, Kees
Groetjes, Kees
kees de mol
Re: Fishing Trawler Propitious FR927
« Reply #1 on: April 27, 2014, 12:09:59 pm »
Hello all,
After a lot of grinding and sanding this is the result. Still al lot of work to do but the start is made.
Groetjes, Kees
kees de mol
« Reply #2 on: April 27, 2014, 12:15:02 pm »
Groetjes, Kees
kees de mol
« Reply #3 on: April 27, 2014, 12:17:52 pm »
Groetjes, Kees
kees de mol
« Reply #4 on: April 27, 2014, 12:20:24 pm »
Groetjes, Kees
« Reply #5 on: April 27, 2014, 12:21:07 pm »
Very interesting!   O0
kees de mol
« Reply #6 on: April 27, 2014, 12:21:22 pm »
Groetjes, Kees
kees de mol
« Reply #7 on: April 27, 2014, 12:26:22 pm »
Starting the weathering of the hull. I make use of the salt-chip effect. First you give the hull al layer of 'rust' then you wet te hull and sprinkle salt o it. Let the hul with the salt dry and then pray the colour on it. Then you let this dry for a day and then you brush the salt away and the 'rust' will pop out.
Groetjes, Kees
kees de mol
« Reply #8 on: April 27, 2014, 12:28:41 pm »
Groetjes, Kees
kees de mol
« Reply #9 on: April 27, 2014, 12:29:43 pm »
Groetjes, Kees
kees de mol
« Reply #10 on: April 27, 2014, 12:33:20 pm »
Weathering the prop using electrolyse
Groetjes, Kees
wicker
« Reply #11 on: April 27, 2014, 12:35:39 pm »
looks great will follow this build with interest - Charlie
« Reply #12 on: April 27, 2014, 12:59:00 pm »
Looking good kees....... :-)) very realistic
this one looks like sauted garlic in butter w  black pepper O0.....Derek
kees de mol
« Reply #13 on: April 27, 2014, 01:06:48 pm »
this one looks like sauted garlic in butter  O0 .....Derek
http://i95.photobucket.com/albums/l142/keesdemol1/DSC06859_zps15954514.jpg
It didn't smell like that, believe me.
Soon there will be more updates and then I try to write something in English with every update
Regards, Kees
Groetjes, Kees
kees de mol
« Reply #14 on: April 27, 2014, 01:29:31 pm »
Here's how the hull looks now after again a bit of weathering.
Groetjes, Kees
Big Ada
« Reply #15 on: April 27, 2014, 06:29:12 pm »
Is it a static boat, ie not remote controlled.
Len.
kees de mol
« Reply #16 on: April 27, 2014, 06:31:35 pm »
Hello,
It's a static model. The model is made of solid mdf.
Kees
Groetjes, Kees
« Reply #17 on: April 27, 2014, 07:15:44 pm »
amazing techniques.thanks for sharing them......brilliant stuff. neil. :-))
kees de mol
« Reply #18 on: April 28, 2014, 10:17:42 am »
Hello,
Is it possible that a moderator moves this discussion from R&D to buildingdiscussions? I misplaced it.
Regards, Kees de Mol
Groetjes, Kees
« Reply #19 on: April 28, 2014, 10:31:17 am »
Have you been teaching eddiesolo  {-)
kees de mol
« Reply #20 on: May 10, 2014, 08:05:08 pm »
The hull is almost finished but thats for later. First I gonna make a start with the superstructure
First I cut a base-plate and I attached it to the hull.
After this I glued strips of styreen to fit some horizontal strips on it. On this I will later glue the deck.
After this I placed the deck.
Here's the start with the wheelhouse. It was very difficult becouse of al the different angles.
The reardeck in it's rough shape
And the sides are glued on.
After this I used al lot of filler and sanding to make all things smooth. It's a little bit strange, just e few words and pics for so much work. But I hope you enjoy watching the pics.
Kind Regards, Kees
Groetjes, Kees
chris gillespie
« Reply #21 on: May 10, 2014, 08:16:29 pm »
Great work
Im enjoying this very much
RAAArtyGunner
« Reply #22 on: May 10, 2014, 10:07:44 pm »
The bread and butter method seems to simply the hull construction.  :-)) :-))
Interesting subject and build  O0 O0 O0
mog10
« Reply #23 on: May 10, 2014, 10:29:32 pm »
Great rust effects  :-)) :-)) :-))
mark w
  • "I stick my neck out for nobody"
« Reply #24 on: May 12, 2014, 05:24:26 pm »
Great work
+1. Love your work.
Mark
"If she can stand it, I can too, play it"
Pages: [1] 2 3 4   Go Up
Page created in 0.097 seconds with 21 queries.
