Hi all,
I have a Angling Technics Procat Mk2 bait boat which is great. Bought it with a friend 2nd hand last year and used it successfully for all of last summer (upto around 8/9 fishing trips).
The boat performed on every use last year and was put away under my mates bed with its batteries disconnected (but the handset/transmitter batteries still connected). Went to use it last week and having problems with it.
When the boat is turned on, the motors run all the time with the control sticks in the central position, when the control sticks are moved to certain positions the motors will stop or change the noise they are making (guessing caused by a slight change of direction). When the channel of the right hand control stick is changed to N rather than R, the boat responds as if the handset/transmitter isn't turned on. Adjusting the trims also has the same effect.
I have had the controller open and found that it looks to have got damp at some point as half of the PCB is furry and the components dont look to be in good shape. Is this likely to be the cause of the problem or more likely to be something int the boat itself?
Any suggestions are appreciated, although we have tried recharged/different batteries and I have crystals on order, as we are really keen to get this fixed (and try not to send it back to the manufacturer).
Many thanks in advance!
