Author Topic: hi everyone new here  (Read 1622 times)
carlseawolf
« on: August 10, 2014, 01:45:51 pm »
Hi everyone ,
     i'm new to this model boat building and my first build may seem a little wild to start with, but i believe if you do a model you have passion in rather than what's expected you will do a better job.
   As you will see it's just a drawing of a video game i play and that's about it. ( there is one other drawing on square paper that gives me a outline from above)
Re: hi everyone new here
« Reply #1 on: August 10, 2014, 01:54:59 pm »
Wow  :o
That is one complicated hull form, or should I say Two  %% %%
Are you going to make a couple of plugs and mould the hulls?
OR are you making frames and sheathing with ply?
If you can get the hulls correct then the rest will be a bit easier %) %)
Welcome :-)) :-))
carlseawolf
« Reply #2 on: August 10, 2014, 02:08:29 pm »
I'm making the hull out of 4 mm ply and had to work out a scale to work from , to simplify the hull abit i have changed the 2 hulls each side to a V shape in the middle to make it an easier hull form to build as there was not enough space to put in 2 small hulls.
 The model is 4' long and about 2'6" wide , and i am hoping to make it into an rc model.
As you see i have no below waterline plans so by joining the 2 small hulls gives me more room inside for the battery / engine and all the delicate electrics will be going into the wheelhouse.
The hardest thing about this build is making a thing not intended to sail, work
carlseawolf
« Reply #3 on: August 10, 2014, 02:18:23 pm »
to give you a clue what im working with this is the other drawing - im using 2 cm per square.
you will also notice it a different version as it has longer bow points , and different gun placements - there has been 5 different versions of this boat and i could not find any more plans than these 2.
so it's a make do and mend
Page created in 0.101 seconds with 22 queries.
