I need to construct a stand alone wtc...ie, a wtc with motor and rudder attached to the cylinder, which will operate on it's own and can be removed from the boat in one piece without any electrical or mechanical connections.
The cylinder will contain a single motor, rx, rudder servo and esc, and a battery pack, and will be fitted to the hull bottom via two Terry clips, so it just unclips as one complete unit. Does that make any sense?
Take a look at the attached image and see what you think, guys...thanks.
