Pages: 1 2 [3] 4   Go Down
Author Topic: bronco type 23 build  (Read 22232 times)
petesubman
Re: bronco type 23 build
« Reply #50 on: September 21, 2014, 07:13:49 pm »
I suppose you could, the plan was to never having to open it up , but thats me it , seems  a good idea, the aft lower hull is removable to access  the charging and on of circuit,  once the battery is fitted it shouldn't need removal unless theres a problem, pete
petesubman
« Reply #51 on: September 21, 2014, 10:08:10 pm »
Ive just won a u25 , pete
U-33
  • K-157 Vepr. Akula-11
« Reply #52 on: September 22, 2014, 08:04:22 am »
The eBay One, Pete?
petesubman
« Reply #53 on: September 22, 2014, 02:24:59 pm »
Yep , cant believe it, pete
redboat219
« Reply #54 on: September 22, 2014, 03:53:31 pm »
Pete,
         Can you provide a drawing or diagram showing the location of the wtc, battery and air bag?
"Better is the enemy of good enough"
petesubman
« Reply #55 on: September 25, 2014, 10:59:26 am »
Hi redboat , this is the best l can do, looking at it again maybe I should have sited the wtc higher in the hull which would have allowed for more ballast below and increased its stability, regards pete
redboat219
« Reply #56 on: September 25, 2014, 11:31:59 am »
Perfectly OK. :-))
I see no provisions for controlling your bow planes. So I assume these will fixed.
BTW, Can you post close up photos of the access panels for the stern plane control linkages.
petesubman
« Reply #57 on: September 28, 2014, 08:38:17 am »
This is a view of the lower stern access panel , this pic was taken early on the build , instead of rod for rudder and stern planes , I used short length bowden cable, with bellows the inner cables are also o ringed onto the inner cable , because im  using rcabs all seals need to be 100%
You can just make out the back stop for wtc, which has now been drilled to hold the wtc in place, there will also be simple on off and battery charge connection, using a waterproof fuse holder,  when get some time I will post pics of its test run, pete
redboat219
« Reply #58 on: October 14, 2014, 03:28:37 pm »
Any updates?
petesubman
« Reply #59 on: October 14, 2014, 09:30:37 pm »
The boat is about ready  to go waiting for a smaller battery , just got a waterproof fuse holder to use as charge socket , on off, will post more pics , pete
petesubman
« Reply #60 on: October 16, 2014, 08:28:52 am »
View of the water proof fuse holder, regards pete
redboat219
« Reply #61 on: December 09, 2014, 02:29:13 am »
Any updates on this build. :((
petesubman
« Reply #62 on: December 09, 2014, 10:20:21 pm »
sorry redboat been tied up with end of term assessments  and paperwork ,hoping to sail it in the new year, will take some pics,regards pete
redboat219
« Reply #63 on: December 10, 2014, 01:02:05 am »
Ok. Advance Merry Christmas to you.
mickyrubble
« Reply #64 on: December 10, 2014, 04:42:27 pm »
Keep the build going when you get time as im following it as well
redboat219
« Reply #65 on: April 03, 2015, 05:47:39 pm »
Any new developments on this build?
petesubman
« Reply #66 on: April 03, 2015, 06:44:55 pm »
Hi  unfortunately  I lost the boat at our slipway where i test my models,it is in deep water  there was a large air bubble Im hoping the wtc wasnt compromised, I have a sub aqua mate on stand by, its wrapped up in the wee.  , lets hope, Pete
salmon
« Reply #67 on: April 03, 2015, 06:54:54 pm »
Pete,
I am sorry to hear about the loss of your sub. This past summer, my XXIII also went missing. Still at the bottom of the lake. Sigh.
I hope your friend can find it and bring it back.
Peace,
Tom
If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.
redboat219
« Reply #68 on: April 03, 2015, 06:59:32 pm »
 <:( <:( <:( I hope you recover her soon. Anything to share about the test before you lost her?
U-33
« Reply #69 on: April 03, 2015, 07:15:03 pm »
Pete, I'm so sorry to read your post, mate...been there, done that, so I can sympathise with you. I hope your mate can locate the boat for you and bring her back.
Good luck mate, keep us informed.
petesubman
« Reply #70 on: April 05, 2015, 05:22:44 pm »
Hi Richard  ,yes I'm  annoyed  with myself, I'm  back there tomorrow taking the dingy out to have a look, Pete
« Reply #71 on: April 05, 2015, 05:32:41 pm »
Maybe when U-33 has his motorflote complete he can get george have a look for you - i believe the motorflote will submerge at full speed, and with george's flatulance problem, he'll race along the bottom quite quickly till the pusher bars make contact and then surface - when he does you know where the sub is - possibly  :}
redboat219
« Reply #72 on: June 11, 2015, 03:38:57 am »
What ever happened to your search and retrieval operation?
Davy1
  • Association of Model Submariners
« Reply #73 on: June 11, 2015, 05:32:41 pm »
Sorry to hear about the loss of your sub, and it is easy to be wise after the event, but I never put a sub in the water unless I have put a Pinger on board:
http://www.theassociationofmodelsubmariners.com/t26-pingers-and-hydrophoneso
I have to say that after this length of time the Pinger battery would be flat anyway(lasts about a month) and the model will be covered in silt and difficult for a diver to spot (particularly in poor viz)
My sympathy goes with you and sad to say you may have to write this one off.
David
petesubman
« Reply #74 on: June 13, 2015, 09:14:58 am »
Hi thanks for your comments I have been searching using  my dingy but as you  say its probably got a  good covering of silt, the water does drop in the winter,  we did lose three gnomes off  our mooring, please dont ask! , but i did find them in mud , I could always build another one.
Pages: 1 2 [3] 4   Go Up
