Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12   Go Down
Author Topic: FISHERIES RESEARCH VESSEL SCOTIA  (Read 83911 times)
Re: FISHERIES RESEARCH VESSEL SCOTIA
« Reply #200 on: December 08, 2017, 09:23:42 pm »
Hello Seaspray - well, I have to say your work on the bridge roof looks great. :-)
As for the mast, like most construction jobs in this game, I'm sure will look the business once painted up - keep it going. :-))
Seaspray
« Reply #201 on: July 16, 2018, 07:44:16 pm »
Meanwhile back at the ranchpic 1 soldering up the bridge roof hatch guardpic 2 guard painted and glued in positionpic 3 using my faithful drill shaping the radar domes for the bridge roofpic 4 domes ready for assembly and paintingpic 5 starting to solder the railing on top of the wind deflectorpic 6 railing finished note the supporting rods inside the top of the deflector
Seaspray
« Reply #202 on: July 17, 2018, 08:18:53 am »
I redone the gooseneck vents as the last lot surfaces went soft
pic 1 the goosenecks sprayed up and coat with varnish
pic 2, 3, 4 the finished bridge top secured in place
hama
« Reply #203 on: July 17, 2018, 11:54:09 am »
Nice to see you back at it!
It looks fantastic as usual.
Hama
Seaspray
« Reply #204 on: July 17, 2018, 01:54:45 pm »
hama  :-)) Nice to be back took a while but got here.
Seaspray
« Reply #205 on: July 18, 2018, 09:59:54 am »
A little gangway between the winches. I have two versions to choose from and went for the one in the images 1972,1973.
Currently doing the railings.pic 1-5 little gangway part built.pic 6 that lazy horse is on my chair again at least its warm when I go to sit on it.bare with me lads having trouble with computer pic 6 write up should be on a new line Martin is on it hopefully
Seaspray
« Reply #206 on: July 22, 2018, 09:20:18 am »
Gangway built
pic 1, 2 brass rail being built
pic 3,4,5 rails removed and sprayed up then glue into position
Tafelspitz
  • Model Boat Bedlam
« Reply #207 on: July 23, 2018, 06:44:17 am »
Neat!  :-))
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
Seaspray
« Reply #208 on: July 23, 2018, 04:55:12 pm »
Thanks  :-)) it took I while to build but its been rewarding
« Reply #209 on: July 23, 2018, 07:59:23 pm »
You are another superb builder and that last work shows it. Poor old dawg, he looks like he could do with a fuss  :}
Seaspray
« Reply #210 on: July 24, 2018, 08:01:16 am »
ballastanksian  :-)) Thanks my quaility of work is down to my mentor John W E and thanks to Riggers for introducting me to John. Must admit that it does take a few or more tries to get it right or near enough.When I meet John I wasn't great at reading plans. Cheeers to them two lads as well
nmbrook
« Reply #211 on: July 29, 2018, 11:51:00 am »
Very nice work Seaspray :-))
Nigel
Seaspray
« Reply #212 on: July 29, 2018, 03:12:04 pm »
 Nigel  :-))
Its a rewarding hobby, thanks
Seaspray
« Reply #213 on: August 03, 2018, 03:40:08 pm »
Building the work boat 7 pictures of some of the build More  pics tmo sick computer  %%
Seaspray
« Reply #214 on: August 04, 2018, 10:24:25 am »
6 more pictures of the work boat build. Now ready for a clean up and spray.
Started on the rescue boat.
« Reply #215 on: August 04, 2018, 05:36:57 pm »
A big thumbs up for the work on your boats  :-))
Seaspray
« Reply #216 on: August 05, 2018, 07:27:26 am »
ballastanksian cheers  :-))
Now working on the railings around the forecastle and and each side of the main deck.
More pics today of the rescue and work boats completed
Seaspray
« Reply #217 on: August 05, 2018, 07:32:28 pm »
Rescue boat various pics of the build all will get a good tidy up and sprayed. last 2 pics put into position to see if everything is 0.k.
Seaspray
« Reply #218 on: August 10, 2018, 08:17:42 pm »
Starting to assemble the rails and stanchions a little more tricky as there was some on the bow unlike the Meteor Now lets see if this computer behaves itself
pic 1 started to build the railings like the Meteor on a brass strip but changed my mind.
pic 2 tacked the stanchions in their places and threaded two bottom rails in place 0.4mm
pic 3 shaping the top rail around the bow
pic 4 started soldered top rail into position
pic 5 most of the railing fixed
pic 6 complete railing removed cleaned under hot water ready for spraying
pic 7 sprayed with etching primer and hung up to dry for a day of two
pic 8 slight damage to boat while building the rails and it being laying about for a time a resprayed is being done
steve mahoney
« Reply #219 on: August 11, 2018, 11:43:53 pm »
Nice work on the railings. A section that size and complexity can often end in tears.
Seaspray
« Reply #220 on: August 12, 2018, 07:17:14 am »
Cheers Steve
I done the rails this way as I opt to spray them off the boat. As painting them would be a pain in the butt. Anyway most of the white acrylic paints now a days is that thin its like painting milk on the railing. Although I have found 2 paints that have a little more body to them.  The first one is from the Games Workshop called Citadel, Ceramite White a base and with a little water added it has a reasonable coverage. Second one is Model Colour''s Acrylic, White, RAL 9016 it to is good. Ammo's their Signal Green A-.MIG-054 is almost a good match for Halford's Ford Mondena Green which I use for the decks
I don't use Humbrol or Tamiya paints anymore
Seaspray
« Reply #221 on: August 19, 2018, 08:45:57 pm »
Few picture of some little work done in the last week as I've been painting and decorating
pic 1,2 I have to use what wood is available and when the grain is open I use P38 smeared over the wood. Then run it down smooth with my drill. I will do this with ply in the future as it has been lying around the place for years.
pic 3 This lot of wood will become the two cranes when assembled.
pic 4 Railings all spray up with a coat of etching primer, a thin coat of white primer and then a coat of appliance white. Just got to scrap the paint of the bottom of the rail ready to insert rails into the deck.
pic 5 As the model has been knocked about for years a respray here and there was required. Just the hull bottom the spray with lacquer,job done
Seaspray
« Reply #222 on: August 23, 2018, 10:04:14 am »
Main deck and forecastle deck railings. The railings  were a good fit after being sprayed up and fitted to the boat. But should have glued then as I fitted them in the first place. Removing them to glue caused a few problems. A little adjustment here an there a touch of paint and I think they'll be o.k.
Pic 1 Starting to fit rails
Pic 2,3, 4. Rails glued in place
Pic 5, 6. Starting to look like a boat now
Tafelspitz
  • Model Boat Bedlam
« Reply #223 on: August 23, 2018, 10:48:05 am »
Coming along nicely!  :-) :-))
Seaspray
« Reply #224 on: August 23, 2018, 06:26:30 pm »
Cheers Dom just doing it as I have time. Your build is coming on too.  :-))
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12   Go Up
Page created in 0.116 seconds with 21 queries.
