Has anyone tried this out? Its a polyurethane based adhesive. Before I go ahead and use it to fasten my frame members into my hull I thought I'd see if anyone else has tried it and what the end result was. I've used it to fasten a bow thruster motor mount into the hull and it seems very strong as the glue foams up to fill gaps. My one worry is that it will not bond to the grp very well, although the advertising blurb underneath says it bonds anything to anything...
Tough, Expanding, Sticks-to-Everything Glue dampIt, glueIt, clampIt,
waterproof, strong, expands
The product that started it all. Original Gorilla Glue built a name for itself with its incredible, industrial holding power and versatility. Water activated, it expands into materials to form an incredibly strong bond to virtually anything. Gorilla Glue is your solution for almost any project or repair. It’s 100% waterproof, safe for indoor and outdoor use and strong enough to stand up to the elements. Plus, its expansion allows it to penetrate the glued surface for a superior bond. Sand it, paint it, stain it. Simply stated, it’s the Toughest Glue on Planet Earth.
