George,
(And anyone else)
Referring back to replay #97-98 on page 4.
I am adding a reversing set to my already running D10. So I have a set of eccentrics with bosses.
My spatial visualization is somewhat lacking these days. and I am trying to determine the orientation of the new
eccentrics in relation to the old.
So to paint a picture:
Each eccentric has a "lobe" - as the engine revolves the lobes move the sheaves up and down.
Easy without the reversing kit.
With the reversing setup in place, each cylinder now has a second lobe on the crankshaft.
They are offset by 120 degrees. I am trying to determine if the offset is in the same
direction for each cylinder. as the cylinders are "mirrored" in orientation.
So:
When rotating in a CW direction, when viewed from the flywheel, Cylinder1, closest to the flywheel,
has the "Bossed" outside eccentric lobe - leading the inside "new" eccentric lobe.
When you then turn the orientation of the engine so you are looking at the other end of the crank,
you are now rotating in a CCW direction.
Big question: Does the Bossed Eccentric Lobe on Cylinder 2 still LEAD or FOLLOW the lobe on the new eccentric?
Same concept - but different view-
With the Eccentrics pinned together and the two sets side by side, are they identical in orientation?
or are they "Mirrored" ?
Hope this makes sense, I am at the point of drilling the holes for the pins and want to get my angles right.
Thanks again,
Jim Pope
Denver, CO
USA
