greetings-Happy New Year to you all
Fitted motor/shaft to my Envoy tug, it is aligned without any obvious wobble, I have put reference lines on the hull interior to sight the coupling to and it looks spot on. However the motor sound like a hammer drill.
I have about 1mm end float on shaft as advised on here.
I have removed coupling and attached drill to shaft.....no noise, even when moving drill from side to side/up and down
I have refitted coupling with 6mm drill bit in motor end and attached this to drill...no noise, even when moving drill from side to side/up and down
I have run motor, fixed to hull but not driving shaft...no noise
put it all back together and all hell breaks loose
Using a Hyco?/? coupling but that doesn't seem to be problem as it runs ok when powered by drill
Motor bed is firmly bedded down, no cavities underneath
It sounds to me that the motor is under stress, but all runs freely
I am running at max as speed controller no fitted yet
Motor is a MFA919d with 2.5/1 reduction
really need help with this problem, thanks in advance
Jenga
