Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16   Go Down
Author Topic: SD 14 Card Model  (Read 92867 times)
Howard
Re: SD 14 Card Model
« Reply #125 on: May 01, 2017, 12:32:33 am »
100_3166100_3167
Howard
« Reply #126 on: May 01, 2017, 12:40:37 am »
I use plastic water pipe and plastic pipe clips plus end stoppers for one end screwed to the underside of a shelf  keeps them all sorted and handy.
                      Regards Howard.
« Reply #127 on: May 01, 2017, 07:16:53 am »
Photos a very small .....  {:-{
Howard
« Reply #128 on: May 01, 2017, 12:34:49 pm »
Sorry  Martin but cant seam to make them bigger can you.
             Regards Howard.
« Reply #129 on: May 01, 2017, 12:53:50 pm »
Send them to me in an email - Martin@modelboatmayhem.co.uk   :-)
« Reply #130 on: May 01, 2017, 01:12:02 pm »
             Regards Howard.
How do you process them? If you use a hosting site then they should offer a range of image sizes. I use Imageshack but they have a storage limit.
Howard
« Reply #133 on: August 04, 2017, 09:59:28 pm »
Hi Gents,
 Yes am still here back to SD14 Lifeboats I could not find any the size I needed any were so made a plug from card frames and infilled with balsa glued into and on to the card then sanded back to the card frames so i now had a solid plug I really wanted a open Lifeboat  white outside orange inside so try-ed to vag-form them but the small machine just was a little to small the get a good shape, another think, make a silicon mould  and cast in resin maybe but will i have to settle on a solid resin Lifeboat NO   I want a open one so I mixed up a little resin and pored  it into the silicon mould covered the bottom and then swilled it up the sides by turned the mould on its end and kept turning till it started to thicken and go off till it would run no more I put it to one side for a few hours before pulling it from the mould  and wow  am I pleased it worked  the bottoms about a 1/4 of the height but the sides are about what I would say scale thickness just the inners and seats to make  am so so happy. As soon as I can work out Mayhem photos I'll post some of what I have made.
                                                      Regards Howard.
Howard
« Reply #134 on: August 14, 2017, 11:08:40 pm »
Hi Gents,
  I hope up loading theses photo's work
carlmt
    • Linkspan Models
« Reply #135 on: August 15, 2017, 12:00:09 am »
Hi Howard - Hope you are well friend?  :-)) :-))
What you have done with those lifeboats is ideal - good shape and lightweight too!!
A German modeller at the Deans Marine open weekend last September demonstrated the exact same method for lifeboats of many sizes and they came out perfect every time.  Well done on sorting these out - ingenuity wins every time!!!
C :-))
Howard
« Reply #136 on: August 15, 2017, 12:17:01 am »
 Thank you for that Carl coming from you that's one huge pat on the back I have a few spare if you ever want to change yours. Such a enjoyable night watching your build.
           Regards Howard
Brian60
« Reply #137 on: August 15, 2017, 03:16:29 pm »
That's a crafty way of making the lifeboats Howard. I'll have to see if I can do similar for my fast rescue craft when it comes to making them.
« Reply #138 on: August 15, 2017, 03:36:35 pm »
Very nice Howard :-))
I need 2 90mmx40
Double ended clinker
ones for my Cal Mac
ferry.
Did you come across any in
your searches?
Howard
« Reply #139 on: August 15, 2017, 05:32:02 pm »
Hi Ned
Yes I think I did Cornwell models or quay key  If you could make a master am sure I could cast you some. Mine are 110mm x 40mm .
                                           Regards Howard
Howard
« Reply #140 on: August 17, 2017, 12:15:09 am »
Hi Gents,
   The last one I have made I managed to get the bottom (floor) down to about less then 2mm and hull sides to about1/2mm
    so happy  looks scale any thinner and I'ed think it would be  to weak.
                                    Regards Howard
Howard
« Reply #141 on: January 19, 2018, 02:18:49 pm »
Hi Gents,
   Just to let anyone still watching my build thanks for keeping a interest  the shipyard has now reopened only a few odd jobs to do finishing the outdoor  to do like making a worktop bridge across the garage (photos to follow) makes building more comfortable .
                           Regards Howard.
« Reply #142 on: January 19, 2018, 02:26:39 pm »
Waiting with anticipation Howard  :-))
Howard
« Reply #143 on: April 02, 2018, 11:59:59 pm »
Hello guys yes am still here  cant think what this RETIRED thing means had more time to model make when I worked full time spent Easter putting more  strip light up in the garage/outside covered ship yard as builder only put in one so have added another four and need more sockets fed up of changing plugs over another 10 should do as its got its own ring main, plus my daughter is just about to give us our first grand-daughter in the next few days/hours been to hospital three times over Easter just to be sent home again so my job to look after grand-son Three but thinks he's 33, :-)) .
             Regards Howard.
« Reply #144 on: April 03, 2018, 01:26:57 am »
I need 2 90mmx40
ones for my Cal Mac
ferry.
your searches?
I made a double ender and a transom ended boat for my Jupiter ferry ned.............don't know what lengths they are and they are not clinkered boats, and I don't have the moulds anymore..........but still have the two plugs..........will measure tomorrow and put a photo of them on here, and if any good and Howard wants the plugs for future, or carlt they are quite welcome to them if they will do dome for you..........I'll measure and photo them tomoz. neil.
Howard
« Reply #145 on: April 03, 2018, 02:02:38 pm »
Thank you Neil,
 Yes if you don't want them I,ll have them and make a mould of them  and hope one might be right for Ned.
                  Regards Howard.
« Reply #146 on: April 03, 2018, 04:49:45 pm »
Hi Howard,
enclosed are the pictures of the plugs and the finished boats.........I moulded the hulls and then once rubber had set I made the hulls of the boats in thin skins of surface tissue matting and epoxy casting resin, just thick enough so that I could build the interiors..
However sadly for Ned, the double ender is 117 mm long and the transom ender is 108 mm long......but if any good to him or you I can send them on.they were built for my Calmac ferry as per plan so could possibly be ok.....the rubber moulds themselves went up to Scotland with all the other moulds and plugs a couple of years ago,
Howard
« Reply #147 on: August 22, 2018, 11:20:46 pm »
Hi Guys,
 I have some 1inch ali  square tube to run just inside the frames  along the floor tops to add strength  to the model as it's over 7ft long going to epoxy them on to the ply hold bottoms with a good bandage I also have lots of compressed card-angles as you can now get in packing  it's very strong   also thought I might try that to or should I use it to make  the boxes in the holds to keep the lead ballast  in place  120lb plus two 12volt, 2 6volt battery's has any one used this card packing before I look forward to your views.
                             Regards Howard.
Howard
« Reply #148 on: November 25, 2018, 11:28:06 pm »
Hi Guy,
 sorry no updates for months but trying to finish a few others my Canning, my Clyde puffer and my mini berthing tug  plus I have a loft to fit out on stilts and kitchen splash-back wall to tile plus  I see my photos on the build has now gone so will try and reload them from my own file as am always being told its a hobby not a job ( a woman's view)just been told next weekend the outdoor Christmas lights need to be started mine plus daughters across the road. So hope to be back in the shipyard soon into the new year sorry about the C word.
                     Regards Howard.
« Reply #149 on: November 26, 2018, 02:32:12 pm »
yep christmas and clyde are dirty words !!!!!!  {-)
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16   Go Up
Page created in 0.098 seconds with 22 queries.
