Author Topic: 2.4 ghz radio / range / failsafe  (Read 12093 times)
Brigadair
  • Race to enjoy; winning is a bonus!
Re: 2.4 ghz radio / range / failsafe
« Reply #25 on: March 15, 2015, 08:30:21 pm »
Hi Ian
Yes still profess to be a bit of a dim whit on this, thanks mart for the endorsement!!!
Joking apart, I suspect if  a metal rescue boat gets between the signal path of the TX and the model boat it might be a good reason to give the rescue boat a very wide birth!!!!
Or if the metal rescue boat is rescuing near to a buoy, go wide if you can or cut the buoy??
Garry
Best regards
Garry Dickson (BMPRS Committee member and Webmaster)
ids987
« Reply #26 on: March 15, 2015, 10:49:13 pm »
Hi Ian
Garry
Hi Garry, Yes, another reason to give the rescue boat plenty of room. My thinking was though, with both Tx and Rx antennae quite low - especially if the Rx antenna is low inside the boat, something like the rescue boat could cast a long shadow, so you wouldn't necessarily need to be that close; imagine you were kneeling, so that your eyes were at a similar height to the Tx antenna, and you're trying to look at (or through) a point quite low down on the side of your boat.
As earlier, any solid objects will attenuate a 2.4G signal significantly, and with the other effects mentioned earlier, the signal level will be all over the place as you're going round the course, so I got to wondering what would cause a big enough black spot to cause failsafeing. I think a model going side by side possibly could too, and the failsafe timeout will vary from one device to another anyway, so it was a bit speculative....
Brigadair
« Reply #27 on: March 17, 2015, 08:16:29 pm »
Hi mark
Your secret weapon should be a Yorkshire puddin!!! That has enough spatial elongation to keep all demon signals at bay!!!
Best regards
Page created in 0.115 seconds with 21 queries.
