Pages: 1 [2] 3   Go Down
Author Topic: My 1st 3D printer  (Read 22376 times)
U-33
  • K-157 Vepr. Akula-11
Re: My 1st 3D printer
« Reply #25 on: February 05, 2015, 11:26:44 am »
I forsee a queue forming at E2V's door with lots of lists in lots of hands...mind you, the beer vouchers could come in handy.
« Reply #26 on: February 05, 2015, 12:30:51 pm »
Its already started with chaps from work and my local RC car club lol
U-33
« Reply #27 on: February 05, 2015, 12:32:44 pm »
But yes once I've had chance to do some more testing, Ill be happy to run off the odd prototype
?? Unreadable, chap...
« Reply #28 on: February 05, 2015, 12:35:14 pm »
Should be now
U-33
« Reply #29 on: February 05, 2015, 12:36:23 pm »
TheLongBuild
  • Build em, and play hard..
« Reply #30 on: February 05, 2015, 01:24:22 pm »
Ad on tv last night for a part work build your own 3d printer  think the price was £25.00pm for 12 months( could be wrong)
« Reply #31 on: February 05, 2015, 06:07:26 pm »
Its over 2 years not 1, makes it quite expensive and it's based on quite old tech, so will be pretty much obsolete by the time it's finished.
2 of the chaps at work have the one on banggood.com and are praising it very highly, although the build area is smaller than mine
I'll post a link later as I'm on the iPad and copy n paste is not its strong point
« Reply #32 on: February 05, 2015, 09:24:15 pm »
Right.... feed jam fixed :) (so far lol)
Looks like the feed motor pinion for want of a better word had not been tightened properly or had worked loose.  A drop of blue theadlocker and a quick tighten.... job done
Another issue was the feed tube....the filament was not running freely through the tube causing stoppages.  Some research online yeilded that these tubes are indeed problematic, and should be replaced with PTFE tubing
Print job now running :)
JimG
« Reply #33 on: February 05, 2015, 09:57:10 pm »
A very useful object to print, nice and simple although it does take around 2 1/2 hours to print.
http://www.thingiverse.com/thing:71502 epoxy bottle holder.
Jim
Dundee Model Boat club
« Reply #34 on: February 05, 2015, 10:49:13 pm »
Noisewise its not much louder than an inkjet printer.
Print job at 14% and looking good so far :)
« Reply #35 on: February 05, 2015, 10:51:36 pm »
ok if it is only at 14% now are you going to trust it to do it's own thing overnight or can you stop and restart it....I wouldnt like a hot machine running without supervision
« Reply #36 on: February 05, 2015, 11:03:49 pm »
now at 36% ill shut it off at midnight lol.... tho you can pause the print
the current print job is started about 10:30pm.  Had a few more feed issues which I have solved by changing the Filament to a new roll.
Checking the roll that was supplied the dimameter was inconsistent which was what was causing the jams
Calimero
    • Calimero's RC shed
« Reply #37 on: February 05, 2015, 11:34:29 pm »
Longest print I've done so far was 44 hours.
Over the past few days I've been printing parts for a 1:16 20ft container. Each part takes between 7 and 10 hours to print (I print quite slowly). At some point I was worried there'd be enough material on left the roll to complete the print. Was a bit of a close call : there was only ~2m left after the print was complete (keep in mind there's approx 60cm that runs to the print head and is always lost).
Big Ada
« Reply #38 on: February 06, 2015, 04:44:04 pm »
I can post up some pics of last nights attempts but there's nothing much to see.... Some cubes and circles of plastic
As for a how to, I found a very interesting book online. Pm me your email and I'll send a copy
When I have access to a decent keyboard (not my iPad) I'll post a more in depth review with pics
PM sent.
Len.
« Reply #39 on: February 06, 2015, 05:22:19 pm »
Big Ada
« Reply #40 on: February 06, 2015, 05:38:56 pm »
« Reply #41 on: February 06, 2015, 05:50:01 pm »
Not contributing to thread but related to 3D printing socially
http://www.bbc.co.uk/news/technology-31164440
« Reply #42 on: February 06, 2015, 05:56:01 pm »
Read this on here earlier. I think ;D
Subculture
    • Dive-in to Model submarines
« Reply #43 on: February 06, 2015, 05:59:02 pm »
Saw this linked on another forum. Something a bit more interesting to print out, which might serve your interest a little better.
http://tim.cexx.org/?p=1282
« Reply #44 on: February 06, 2015, 06:55:11 pm »
Nice
Will give that one a go.  Maybe not to use in anger but more as experience
« Reply #45 on: February 06, 2015, 07:50:14 pm »
getting there
I cant seem to get it printing in HQ mode without making a mess :(
However the more tinkering I've done the better the prints.  It just takes time to get the feed rates and nozzle temps right.
I think I will stick to one brand/supplier for filament as I have noticed that different filaments require different settings.  I have 2 spools from the same supplier (red and Black) and they work better at different temps (190 for black and 200 for red)
Have to say tho its quite time consuming and its not really something you can just plug in and go, no matter what the adverts say.
My initial conclusions are that its a great bit of kit with huge potential, but the finished quality isn't quite there at the budget end of the spectrum. (If you can call 400quid cheap lol)
I think mine will be used to prototype parts with the finalised parts being ordered from Shapeways
If anyone wants anything printed as a proof of concept/prototyping then I'm happy to do so.
« Reply #46 on: April 15, 2015, 12:30:56 pm »
A little update :)
Trying to use the water soluble PVA filament ended up ruining the nozzles as when the stuff overheats its burns and leaves a residue thats nigh on impossible to remove.
On the whole its working OK, but more even tinkering is required
vnkiwi
« Reply #47 on: April 15, 2015, 02:56:06 pm »
Good luck with your 3D printing.
I had a miniUP! printer for 18 months or so, and initially, produced good results.
But how you form your cad model also has an effect on quality.
A major move on my part last Christmas, means I no longer have either of my printers.
The attached photo is of a horizontal steam engine at 1/10th scale. The file was for a full size engine.
This was a complete set of parts right down to the piston rings, and all printed successfully, but could not repeat this quality just before I gave the printer away.
Stick with one supplier for your filament, it varies so much, and remember - rubbish in rubbish out.
And it does absorb moisture, so keep it in an airtight container, with silica Gel.. until needed.
cheers :-))
« Reply #48 on: April 15, 2015, 06:37:17 pm »
The things I have been producing have been pretty simple.
I have been using Tinkercad
https://www.tinkercad.com/
you need to register but its quick and easy to pickup
Heres the servo mounts I designed an printed for my Tirpitz Build:-
A simple U bracket to fit the turret servo
Rudder servo mount
A bit of overkill perhaps but It was fun designing it and I can simply upscale it for larger servos
« Reply #49 on: May 04, 2015, 11:09:16 pm »
Not to be funny, but you could build almost true prototypical Liberty ships or X-Lighters using this type of printer. Printing the hole for the prop shaft is just the beginning, you could print integral motor mounts and even gear box casings with input and output orifices attached and aligned to the hull!
It is definitly the way ahead.
Pages: 1 [2] 3   Go Up
Page created in 0.11 seconds with 21 queries.
