Ramon......
I have a Anton V71 Gas regulator, the spare or replacement diaphragm as supplied is 13 diameter x
0.7 thick Nitrile [NBR].....[not natural rubber according to JMC]
As we know Nitrile is comfortable with temperatures to say 90 degrees C, however certainly a longer life expectancy could be attained by reducing this temperature
So from this I have taken the water pilot signal source from the bottom of the boiler at ~~~~~just under 100 degrees C, and this cools to approx. 70 degrees C at the regulator as opposed to taking the pilot as steam from the top of the boiler at ~~120+ degrees C
We have read of members stamping out such diaphragm's from bicycle tyre tubes ..........or bicycle puncture repair kits
I have also installed an isolation valve in the water pilot line just before the regulator so I can bleed the line, then commission & test the plant with the gas regulator in line but non functional............
Will this regulator be intended for the beautiful Wide-a-Wake vessel & engine build on the other WEB thread?...........Derek
