Pages: 1 [2] 3   Go Down
Author Topic: Bobby Police Launch  (Read 20583 times)
Subculture
    • Dive-in to Model submarines
Re: Bobby Police Launch
« Reply #25 on: May 06, 2015, 10:02:00 pm »
A 400 should give it sprightly performance. If your daughter finds it a little too quick, just drop the voltage down a bit.
escipion
« Reply #26 on: May 07, 2015, 04:38:29 pm »
Ok, I'll keep that in mind, thank you very much
TheLongBuild
  • Build em, and play hard..
« Reply #27 on: May 08, 2015, 07:52:19 pm »
HI
Found this clip I took of a enlarged version of Bobby and fitted with IC, at the EPort show 2011
https://www.youtube.com/watch?v=l9XNWiuGtfw
escipion
« Reply #28 on: May 08, 2015, 09:25:31 pm »
Thank you very much
Nice video  :-)) , she really goes fast
Have a nice weekend
escipion
« Reply #29 on: May 11, 2015, 05:48:09 pm »
Hi Guys!!!!
I was planning about painting the launch in red and dark blue the hull with white the cabin and gray the cabin and deck, but, as I’d already comment you, my little daughter decided It’s going to be her launch, she decided she’s going to have different colors: purple, pink and blue, some kind of barbies combination.
I had some troubles with the pink, believe it was an old painting can and took me about one week to let it as I want.
I already made a new rudder, following your advices, looks better now
Best regards
escipion
Painting and base
« Reply #30 on: May 18, 2015, 04:18:29 pm »
 Hi Guys!!!!
I’ve been working slowly but didn’t stop. Made the base, varnish it and put some rubber to protect the boat. Finished painting the cabin and in other things, I’m making and painting the cabin and deck details. Send you a picture as she is by now
I feel the colors look good, discovered the details stand out in white color, by now I’m painting them, I’ll send you a picture when they are already mounted
Best regards
« Reply #31 on: May 18, 2015, 05:31:53 pm »
love the colour scheme....... O0 O0
escipion
Horns
« Reply #32 on: May 22, 2015, 05:04:18 pm »
Hello!!!
Thank you for your comment Neil
I've been working in the lathe a couple of hours making the horns, as the launch have no specific scale had to do them by feeling, want your opinion, feel like they are a little larger, haven't mount them yet, send you a couple of pictures
Nice weekend
« Reply #33 on: May 22, 2015, 05:50:30 pm »
that looks just about right to me. :-))
« Reply #34 on: May 22, 2015, 06:03:27 pm »
They look perfect.
escipion
« Reply #35 on: June 08, 2015, 08:00:18 pm »
 Hi Guys!!!
Thank you for your advice, decided to put those horns
By now I’ve been working a little slowly. Already made, paint and mounted the hand rails, even installed the front bollard, the front hatch and the horns, all with small bolts and adhesive.
Best regards
NobbySideways
  • Fairey Huntsman 31 Build in progress
« Reply #36 on: June 08, 2015, 08:38:41 pm »
What a charming model.
newbe7
« Reply #37 on: June 08, 2015, 09:46:24 pm »
Great build I like the photo's .
Rick
escipion
Rudder servo
« Reply #38 on: June 09, 2015, 03:40:39 pm »
Hi Guys!!!!
Thank you for your comments
It took the time for the rudder servo, the first thing was to make the base, it's made with PVC, only the piece where you screw the servo is made with styrene
Best regards
escipion
Windows and fenders
« Reply #39 on: June 15, 2015, 05:59:25 pm »
 Hello!!!
This week I made and fixed the main cabin windshields, they are made from a CD box in good shape. Next was the bow and stern metal fenders, at the beginning noticed that the PVC use to keep the scratches and the bow is made with this material, so decided to put metal fenders, brass in this case.
Other things I’ve been doing was soldering the motor diodes, adapting the coupler and cutting the propeller shaft (was too long). Have no photos of this, but am sending you the last one I took with the windshields and the brass fenders
Best regards
escipion
Motor
« Reply #40 on: June 29, 2015, 04:40:29 pm »
Hi Guys!!!
By now I installed the motor with the couple. Even I'm working with the situation lights, spend some time with the lathe doing them, they only need painting and installing them
Best regards
« Reply #41 on: June 29, 2015, 04:50:20 pm »
I nick some of "my daughters" nail varnish to threadlock screws & grub screws.   %)
 You'll never find them again if they vibrate loose!
escipion
Thank You
« Reply #42 on: June 29, 2015, 08:51:55 pm »
Thank you Martin!!!
Thank you for the advice, you are right, I'll take that in mind and do it.
Best regards
Krishna
  • aqua plannerrrr....................
« Reply #43 on: June 30, 2015, 04:40:48 am »
great work.. !
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
escipion
« Reply #44 on: July 13, 2015, 05:19:21 pm »
 Hello Guys!!!
Thank you very much Krishna
The launch is almost finished, so I’ll tell you about the things I’ve been doing since the last time I posted the progresses.
 First I painted and mounted the situation lights, even put a hand rail next to the door, believe it should have one
escipion
Mast
« Reply #45 on: July 13, 2015, 05:21:00 pm »
 Then I made the mast with some modifications, added some blue and yellow lights
escipion
Police Launch as she is by now
« Reply #46 on: July 13, 2015, 05:28:50 pm »
 Send you a picture al the launch as she is by now, you can see the mast in his position, added a couple of cleats in the stern, believe it’s too lonely back there; Made and installed the door handles and made the cabin windows, only made two by side in order to let some ventilation for the electronics. Feel like she needs a searching light, so maybe it´s going to be the next step, by now she is more than 100% than the plan.
Krishna
« Reply #47 on: July 13, 2015, 05:47:46 pm »
lovely.. once again.. waiting for a video of her maiden voyage..
escipion
« Reply #48 on: July 13, 2015, 06:03:42 pm »
Thank you Krishna, if everything goes fine, this weekend will be her first trip  :-)
Best regards
escipion
Electronics
« Reply #49 on: July 13, 2015, 06:04:50 pm »
 I can say that the electronics are finished, she is using a 2.4 ghz pistol transmitter, the BEC-ESC is fixed with Velcro, I’m deciding where to fix the receiver, where you see it or up near a window, it have a small antenna.
Already made the first run outside the water and everything seems ok, hope this week can make the final adjusts and make the first run in the pond by the weekend
Best regards
Pages: 1 [2] 3   Go Up
Page created in 0.117 seconds with 22 queries.
