Pages: [1] 2 3 4   Go Down
Author Topic: Gopha Girl ( Springer Tug )  (Read 39731 times)
radiojoe
« on: April 24, 2015, 04:11:42 pm »
Well I hope you guys won't mind but I decided to do a build log on my Springer, If nothing else it keeps me focused, I won't go into great detail, as said there have been quite a few Springers, so I don't want to bore you all, but it might just be of interest to Springer fans.
I'm building a fairly simple traditional top and the hull is set out to the standard formula, Although I'm not going to be that strict, I started by making the rudder, as I had no plywood to hand for the hull at the time, as I said don't want to bore so I'll let the photos do the talking.. %)
radiojoe
Re: Gopha Girl
« Reply #1 on: April 26, 2015, 04:13:04 pm »
A bit more done. ;)
plug
Re: Gopha Girl
« Reply #2 on: April 26, 2015, 06:33:56 pm »
What have you used for the bottom, looks like it bends well
regards Jack.
radiojoe
Re: Gopha Girl
« Reply #3 on: April 26, 2015, 06:49:59 pm »
Hi Jack,  Its 1/8" ply cross grain, yes it bends to the shape quite well if you glue and pin a bit at a time.
Re: Gopha Girl
« Reply #4 on: April 26, 2015, 09:38:13 pm »
It looks good.    :-))     Aren't they fun to build.
ken
radiojoe
Re: Gopha Girl
« Reply #5 on: April 26, 2015, 10:47:23 pm »
HI ken, they sure are, as it says in the forum (Bringing back the Fun into model boats!) I'd agree with that,  ;)
Re: Gopha Girl
« Reply #6 on: April 26, 2015, 11:08:00 pm »
john44
Re: Gopha Girl
« Reply #7 on: April 27, 2015, 08:03:48 am »
They are not just fun to build, they are great fun to sail on the lake.
radiojoe
Re: Gopha Girl
« Reply #8 on: April 27, 2015, 09:38:35 am »
Yes it makes a nice change to build something simple out of the head so to speak, (lets face it if it's out of my head it's going to be simple) and although I did a drawing I'm adding bits as I go, but she's also has a practical side, if any of my ships are stranded in the lake for what ever reason Gopha Girl might just save me getting wet trousers. %% {-) {-)
Re: Gopha Girl
« Reply #9 on: April 27, 2015, 10:58:15 am »
I don't know if it's allowed but I fitted a keel in the stern section to aid steering.  Just a small one but enough to keep a straight line.
Yes, an ideal rescue boat because of the  'knees' in front.   {-)
ken
radiojoe
Re: Gopha Girl
« Reply #10 on: April 27, 2015, 11:16:27 am »
Yes mines going to have a skeg keel enclosing the prop shaft and same depth as the rudder, not too bothered about Springer rules, it's never going to be used in comps.
Re: Gopha Girl
« Reply #11 on: April 27, 2015, 04:10:30 pm »
Mine has a skeg and a Kort nozzle.
It's called International Rescue down at the pond
as it is launched at least once a week for rescues.
If I made another I would use the fishtail rudder as I
believe it is just as effective as a Kort.
radiojoe
Re: Gopha Girl
« Reply #12 on: April 27, 2015, 06:30:54 pm »
When I designed mine I couldn't decide whether to have a kort or fishtail, have to confess I went for the fishtail because I thought it would be easier to make, it will be interesting to see how it performs. ;)
Big Ada
Re: Gopha Girl
« Reply #13 on: April 28, 2015, 08:39:01 am »
My Springer with a Fishtail Rudder spins 360degrees in its own length.
Len.
radiojoe
Re: Gopha Girl
« Reply #14 on: April 28, 2015, 10:32:00 am »
Thank Len should be quite maneuverable then.  :-))
Bob K
  • Bob K
Re: Gopha Girl
« Reply #15 on: April 28, 2015, 11:00:41 am »
Interesting build Joe.  My Springer has a Kort nozzle, spins almost in its own length.
radiojoe
Re: Gopha Girl
« Reply #16 on: April 28, 2015, 11:09:43 am »
Thanks Bob,  I've heard a lot about them so I thought it might be fun to make one.  :-))
radiojoe
Re: Gopha Girl
« Reply #17 on: April 29, 2015, 02:13:55 pm »
An update,  two coats of sealer to the inside and deck fitted, I also want to make all the deck fittings out of what I can find in my workshop, not that I mind buying them but I thought it may add to the fun, I've loosely based it on 1:24 and made a start on some bollards, later I'll have a go at cobbling together a winch of some sort. %)
Re: Gopha Girl
« Reply #18 on: April 29, 2015, 11:54:59 pm »
The hull shape reminds me of a cubist lute! Already looking forward to the next installment.
radiojoe
Re: Gopha Girl
« Reply #19 on: April 30, 2015, 04:39:11 pm »
Running gear fitted, completed skeg and rudder, next I'll fit the deck up stands. :-)
plug
Re: Gopha Girl
« Reply #20 on: April 30, 2015, 05:51:39 pm »
Really nice job.
Re: Gopha Girl
« Reply #21 on: April 30, 2015, 08:47:00 pm »
Now that's what I call a Tiller Support.   :}
ken
Re: Gopha Girl
« Reply #22 on: April 30, 2015, 10:41:19 pm »
Neat work. I see your oiler on the stuffing tube Joe. Is that a home made bung, or purchased?
radiojoe
Re: Gopha Girl
« Reply #23 on: April 30, 2015, 11:23:55 pm »
Ian, the black cap on the greaser, came from a self assembly garden storage unit the wife bought, it was put together with self tapping screws and there was a bag of these little plastic caps to cover the screws ends, there was a lot left over that I kept, that was years ago well I've finally found a use for them. %%
radiojoe
Re: Gopha Girl
« Reply #24 on: May 02, 2015, 04:05:25 pm »
Finished running gear and tested, fitted hatch upstand and made cover/deck, a snug fit but also used magnets, next I'll make the wheelhouse and funnels.  ok2
Pages: [1] 2 3 4   Go Up
Page created in 0.104 seconds with 21 queries.
