Author Topic: Repair advice  (Read 2992 times)
jfhcircus
Repair advice
« on: May 07, 2015, 09:30:36 pm »
I bought a dirty used Northwind 36, to save it from the junk pile. It was drowned in glue and half finished. But the sails, rigging, rc stuff all OK now but the bulb cover for the keel is distorted along seam  Can' t get it to close when screw the weight into place within the housing. Thinking I would try a filler and close the crack for ever. I think someone has dropped the yacht on the keel, hence crack. Could anyone recommend a proprietary product that would be best.
Reading the advice in the messages, could I say that I have limited skills, or no skill.
Thank you for taking the trouble to read this
Kind regards
 jimmy
john44
Re: Repair advice
« Reply #1 on: May 07, 2015, 10:08:13 pm »
Hi Jimmy, a picture would help with getting advise regarding your problem.
Re: Repair advice
« Reply #2 on: May 08, 2015, 10:38:25 am »
Hi Jimmy and welcome to Mayhem.
You sound a typical Mahemer already......getting stuck in.  I would start the filling with epoxy resin and then sand it flat.  Any further little cracks or imperfections can be filled with P38 light from Halfords as it sands easy and smooth.
Have a go and don't forget to post some pictures as you go along.
ps  The security codes will stop when you have over 5 posts....  tehe
ken
nemesis
Re: Repair advice
« Reply #3 on: May 22, 2015, 06:35:46 pm »
Hi, is this the plastic cover that goes over the bulb? Take it off and polish up the lead, that is what others do when it cracks. Nemesis
Page created in 0.101 seconds with 21 queries.
