Pages: 1 2 3 4 5 [6] 7 8   Go Down
Author Topic: Another Svitzer Maltby  (Read 63277 times)
mersey dave
Re: Another Svitzer Maltby
« Reply #125 on: February 20, 2016, 09:56:22 pm »
Hi Faz, as far as painting the mast I intend on sliding some rubber tube (like heat shrink) over the LEDs prior to painting  this should keep them free of paint. Hope you get what I mean.  :-)) :-)) :-))
Regards Dave.
david48
« Reply #126 on: February 21, 2016, 10:38:29 am »
I do not want to appear to be finding fault ,before you get to far on should some of the LEDS not be red ,just an observation . Good to see you resolved your issue .
David
mersey dave
« Reply #127 on: February 21, 2016, 12:38:21 pm »
David
Hi Dave, you are correct mate I could get around that with coloured lenses but I have the same problem as before now, don't know why it's happened I sprayed it last night then went to it today switched on great then after leaving the lights on while I worked on something else I noticed after an hour or so the lights were flickering and went off. After checking all connections all looked fine so I had to remove a bit of paint in order to check and yes a dead short again, I have now left well alone as it's done my head in I will have another look tomorrow if I can't find the problem then it's getting lashed in the bin and start again......the joy's of model boat's.
Regards Dave.
Captain fizz
« Reply #128 on: February 21, 2016, 04:44:41 pm »
That's a pain Dave, I am watching with interest as I have a similar task coming up on my Ayton Cross build.
I hope you manage to get it sorted without having to start again.
Big Ada
« Reply #129 on: February 21, 2016, 05:58:59 pm »
Does it need resistors ( whatever they are ) in the wiring system?.
mersey dave
« Reply #130 on: February 21, 2016, 06:44:18 pm »
Hi, all resistors fitted mate......it's just one of those faults that's there in front of me but I can't see it at the moment. I haven't given up on it yet. :-)) :-)) :-))
Regards Dave.
mersey dave
« Reply #131 on: February 21, 2016, 06:46:49 pm »
Not to worry, by the time you start on your mast I will hopefully have it sorted or a new one built. :-)) :-))
Regards Dave.
mersey dave
« Reply #132 on: February 28, 2016, 02:20:25 pm »
Got some more done on the brass work as in the rails around the roof area and made the ladder to provide access to the roof, not much more to do in brass once this is done I will make a start on the mast again.
Regards Dave.
mersey dave
« Reply #133 on: March 10, 2016, 11:50:06 am »
A bit more has been done and the crew have gone aboard to have a look around before they go for training. It's getting there slowly.
Regards Dave.
Starspider
« Reply #134 on: March 10, 2016, 03:52:46 pm »
Very crisp like the winches they look the business  :-))
mersey dave
« Reply #135 on: March 10, 2016, 04:42:08 pm »
Thanks Mate :-)), they are from MMB I always use them as you say they look the part. :-)) :-)) :-))
Regards Dave.
tugnut
« Reply #136 on: April 01, 2016, 07:34:03 pm »
Hi Dave, how are you doing hope all is well.
How is the build doing.
regards John.
mersey dave
« Reply #137 on: April 01, 2016, 09:36:04 pm »
regards John.
Hi John, not to good at the moment as you probably know I had my leg amputated last September and had a fall about 3 weeks ago landing on my stump, I am waiting to go back into hospital to have a bit more taken off the bone as they left it a bit to long and it's trying to work it's way out so I have been in to much pain to work on the tug but I shall get going again soon, have to do something mate I'm going potty just sitting around. Thanks for asking mate and take care yourself.
Best Regards Dave.
Fastfaz
« Reply #138 on: April 02, 2016, 12:05:30 pm »
  Hi Mate,
      Sorry to hear about the fall fingers crossed all goes well. When I did my knee I could only bend the knee about 30 degrees foolishly went back to work to early tripped and bent the knee right back ouch!!. Keep your chin mate you'll be okay.
       Kind regards,
           Faz. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
mersey dave
« Reply #139 on: April 02, 2016, 12:43:48 pm »
Thanks Faz, the way I look at it is life has to go on.....so I carry on the best I can and most of all I try and not let it get me down. I am looking forward to getting back into working on my Maltby, it won't be long and I will carry on.  :-)) :-)) :-)) :-))
Regards Dave.
mersey dave
« Reply #140 on: April 12, 2016, 05:24:11 pm »
Ok the new mast has been built, it's now ready for spraying and the I shall fit the dummy lights. Yes I am going this way with the lights....can't be bothered with the messing around with all the wires.
Regards Dave.
« Reply #141 on: April 13, 2016, 12:15:04 am »
Regards Dave.
...yeah, know what you mean Dave.
That mast is looking neat - nice one. :-)
mersey dave
« Reply #142 on: April 13, 2016, 07:24:11 am »
Thanks Ray, when I thought about it I decided for the amount of times I would sail it in the dark I wasn't worth it, I have an Eldergarth that lights up like a xmas tree I can sail at night if I so wish.  :-)) :-)) :-)) :-))
Regards Dave.
16-21
« Reply #143 on: April 24, 2016, 01:23:13 pm »
Dave,
The M class is looking good.
Thanks for all the information you give me via pm.
As luck would have it a Tug that I've liked and been after for awhile
Landed at my door,
I'll probably be selling my Maltby hull and plan on, as i need to reduce what's here.
Best regards
Adam
mersey dave
« Reply #144 on: April 24, 2016, 02:28:49 pm »
Dave,
Landed at my door,
That's a shame Adam, I was looking forward to the build. Never mind what have you got now....must be something good. :-)) :-)) :-))
Regards Dave.
Best regards
Adam
16-21
« Reply #145 on: April 24, 2016, 03:21:34 pm »
Sent you a Pm Dave
Adam
mersey dave
« Reply #146 on: April 24, 2016, 03:37:28 pm »
Sent you a Pm Dave
Adam
Hi Adam, never got it mate.
Regards Dave.
16-21
« Reply #147 on: April 24, 2016, 06:24:47 pm »
Hopefully it's worked this time???
thegrimreaper
« Reply #148 on: April 25, 2016, 08:32:31 am »
So your building TARGETS now Adam we will have to pay you and Scotland a visit with the Typhoon once I get the torps to work properly lol.
good luck with what ever you decide to build next mate.
Mark.
Don't lie, thieve, cheat or steal. The Government do not like the competition.
16-21
« Reply #149 on: April 25, 2016, 11:01:19 pm »
Hi Mark,
Always had targets....
The biggest issue with the subs, Engel
Is the dry weight.
At least I can remove the batteries from The Tug
Making it easier to lift out of the pond.
Perhaps I should pop down your way next year?
Pages: 1 2 3 4 5 [6] 7 8   Go Up
