Pages: 1 2 3 [4] 5 6 7 8   Go Down
Author Topic: Another Svitzer Maltby  (Read 62903 times)
mersey dave
Re: Another Svitzer Maltby
« Reply #75 on: February 06, 2016, 03:50:43 pm »
Managed to get a bit more done, a few bits made and window frames fitted it's coming on slowly.
Regards Dave.
« Reply #76 on: February 06, 2016, 04:18:28 pm »
I must get on with mine, but badly sliced my thumb at the weekend with a Stanley knife, only making a set of sails for someone, but 5 stitches later!!!
Hope you charged extra for the random red patterning Andy {-)
BTW The ones you made me about five years ago for my Victoria
are still going strong. :-))
tugnut
« Reply #77 on: February 06, 2016, 06:13:57 pm »
Starting to take shape now Dave, what are you using for the hand rail stanchions i have just done all of mine  {:-{ .
mersey dave
« Reply #78 on: February 06, 2016, 06:53:35 pm »
Hi John, I have purchased 35mm three rail stanchions they cost a fortune for the amount needed but they should look the part. I have just placed an order for 5 crew members but they were not to bad a price.
Regards Dave.
Starspider
« Reply #79 on: February 06, 2016, 08:26:28 pm »
Very nice work  :-))
colin
andywright
« Reply #80 on: February 06, 2016, 09:31:36 pm »
Regards Dave.
Hi Dave, I got 27mm ones from MMModels, but not sure if they are long enough. Will get some out of packet tomorrow and have a proper look.
mersey dave
« Reply #81 on: February 07, 2016, 02:57:44 pm »
Very nice work  :-))
colin
Thanks Colin. :-))
Regards Dave.
mersey dave
« Reply #82 on: February 07, 2016, 05:17:02 pm »
Got a few bits primed today I am going to make a start on the mast hopefully tomorrow as there is so much work to do in brass I thought I would do it in stages so I don't get fed up.
Regards Dave.
mersey dave
« Reply #83 on: February 07, 2016, 05:27:32 pm »
Hi Andy, 27mm at 32 scale works out at 86cm ........a bit on the small size I would think......your thoughts.
Regards Dave.
« Reply #84 on: February 07, 2016, 05:29:31 pm »
Lovely work Dave:O)
andywright
« Reply #85 on: February 07, 2016, 06:29:05 pm »
Regards Dave.
They were my thoughts to, even adding1mm on top for the rail it still looks a bit low, and definitely scales up to low. Where did you get yours from.
mersey dave
« Reply #86 on: February 07, 2016, 07:16:12 pm »
Hi Andy, got mine from Cornwall Models mate. :-))
Regards Dave.
mersey dave
« Reply #87 on: February 09, 2016, 03:25:46 pm »
Ok today I got round to making a start on the mast, as you can see I am building it from brass with the idea that it can be used to supply the negative from the battery to the lights. It has taken a lot longer than I thought just to get this far but I put this down to having to do it from sitting in my wheelchair, I will get there in the end.
Regards Dave.
Big Ada
« Reply #88 on: February 09, 2016, 05:56:55 pm »
Regards Dave.
Nice work Dave, I will be watching the Mast build and fitting of lights as I want to put lights on the Tug I am making.  The cross tubes in the Mast, did you drill a hole through them to enable wires to pass through ?.
Len.
mersey dave
« Reply #89 on: February 09, 2016, 06:31:49 pm »
Len.
Hi Len, yes mate I drilled holes in the main mast then soldered the cross tubes into them to take the wires.
Regards Dave.
andywright
« Reply #90 on: February 09, 2016, 10:31:52 pm »
I always use the mast for the -ve return on my masts
mersey dave
« Reply #91 on: February 09, 2016, 10:44:17 pm »
Hi Andy, first attempt for me mate so hoping all goes well......I can only try. :-))
Regards Dave.
mersey dave
« Reply #92 on: February 10, 2016, 04:22:09 pm »
Got some more done on the mast, it's starting to take shape.
Regards Dave.
mersey dave
« Reply #93 on: February 13, 2016, 12:34:21 pm »
A bit more done on the mast, as you can see it's all primed ready for the next job of feeding all the wire in for the lights. I intend on using enamel coated copper wire at 0.10mm thickness as there are 12 lights on the mast alone.......not a job I'm looking forward to.
Regards Dave.
oldflyer2
« Reply #94 on: February 13, 2016, 05:04:28 pm »
Very nice job on the mast so far.
A question ... I have some of that enamel covered wire for my mast as well and I was wondering if there is enough vibration from running the boat to rub through the enamel and have a short?
Tom
mersey dave
« Reply #95 on: February 13, 2016, 05:12:12 pm »
Tom
Hi Tom, I have never used it before and was thinking of that myself and trying to think of a way to stop that happening.....maybe someone will give us the answer and solution to the problem.
Regards Dave.
tugnut
« Reply #96 on: February 13, 2016, 07:15:04 pm »
Good job on the mast Dave  :-)) .
Fastfaz
« Reply #97 on: February 13, 2016, 08:25:56 pm »
Hi Dave,
     Have you tried Component shop LED wire? this is what I use and no probs so far (please god) not sure of the actual size/diameter of the wire but I have 9 lights running down the mast of my Eldergarth and that is pos and neg to each light so 18 wires in total. Ring them and ask I don't like the idea of a wire rubbing up to something and shorting it all out! Nightmare to resolve it. Hope this helps.
     Cheers,
           Faz. :-)) :-)) :-)) :-)) :-)) :-)) :-)) :-))
mersey dave
« Reply #98 on: February 13, 2016, 08:39:19 pm »
Hi Dave,
     Cheers,
Thanks Faz, I will have a look into that mate. :-)) :-)) :-)) :-))
Regards Dave.
mersey dave
« Reply #99 on: February 13, 2016, 08:41:41 pm »
Thanks John, I am quite happy with the way it has turned out so far. :-))
Regards Dave.
Pages: 1 2 3 [4] 5 6 7 8   Go Up
Page created in 0.11 seconds with 21 queries.
