Hi Bob, thanks for the reply.
Tried with an old 2ch Futaba crystal set and works fine in 100% mix mode.
Tried FlySky in tank mode and is better, not correct though, soon as you add throttle motor bangs in, also if just using one stick opposite motor spins up for a second.
Think the problem is the FlySky unit, the throttle channel zero position is full down, in the middle it is 50%, hence why motors bang straight in. Tried all sorts to get it into a neutral position but no joy, nothing on you tube either.....this is one purely for the fly boys methinks........oh well better spend some more money.......the Planet T7 looks good value......any reason not to get one?
Stewart
