Next job on the agenda is more holes in the hull!! This time the slots for the propshafts and the rudder supports. Marked out , drilled and filed to suit the angles needed to get the props in the correct place.
Talking of shafts, the ones provided were full outer tubes which are not cotrrect for a Severn Class Lifeboat so it was mark off where the cut should be then deep breath, fingers crossed and on with the cutting disc.
The bearing from the section removed was carefully knocked out and re-fitted, ensuring it was square and straight, into the shortened outer casing. This plus the A frame shaft support was now ready to fit.
View of the starboard shaft fitted in place in the hull.
The rudders were also made using standard brass items with styrene overlays to give the correct shape and size.
The shaft, supports and rudders in place ready to add the bilge keels.
Quick view of the brushless beasts that will power this brute!! The mounts were a pair I aquired a while ago for brushed 900 size motors and the mounting holes were the correct spacing for these monsters.
