Mike...Silicone
...it has some brilliant properties
1. flexibility
2. amazing di-electric resistance as an insulator.......0.00000000000000m units of something
3. capable of withstanding high environmental temperatures...200 degrees C
4. sometimes has been proven to stick to itself
5. is totally waterproof in itself
6. an ideal product as used by NASA and in any humidity controlled clean sterile work room where all components being adhered with the material have equally cleaned sterile surfaces
However personally I would not consider even buying a tube of that GOOP.....................
7. absolutely useless in any application where human hands are involved...and that includes all our model ship workshops.......with dust & grease & paint & ???? and even sweat from the brow
......heaven forbid it drop on to a hull prior to the application of Silicone
8. problem now is how to remove the Silicone?....as fibreglass resin and hardner will not stick to it........they will just cure and leave a minute path for the water to migrate into the hull until the level of the water is sufficient to sink your treasured craft
....you probably can guess I am not a fan of Silicone........Derek
