Author Topic: Fantasy Huntress Build  (Read 18315 times)
imsinking
« on: July 07, 2015, 02:07:04 pm »
I've never  'scratch built' anything , how hard can it be!?
Not keen on doing the hull, found a Precedent Huntsman 31 hull , in need of work , a fortune changed hands (£10 anyway) no superstructure , deck badly fitted etc . . .
Off I went , an EVIL paint scheme had to come off, Black / Yellow / Red flames , being Fibreglass NITROMORs stripper was out , tried everything, Fairy Power spray / Brake fluid , nil . . sanding wasn't denting the paint either , dawned on me that it's HAMMERITE silicone paint  >:-o  idly flicking at it with an EXACTO chisel blade it started coming off !
Out in the yard after a couple of hours it's all off,  they hadn't sanded the hull down luckily & the paint wasn't gripping , the yard looked like a Jackson Pollock painting tho '. . . Out with the frames / propshaft / rudder and anything else N B G
    Having an elderly Aerokits Huntsman I just made cardboard templates of all I need
 I elected to leave the windows / frames cut outs until fitted in place
The hull's now sanded, propshaft in & P framed , holes drilled for the rudder / etc
As I suspected the deck split away & needed re attaching with resin inside & out when I fitted the new internals , also fitted the motor mount bearers
cut a close fitting base for the cabin to be built on , & strapped it to the deck
This will stay in place til the cabin is assembled
Well deck frame ready to go in
Needed to taper the sides to leave an acceptably narrow joint at the top join
you can see the taper clearly here
Cabin sides / frames / front screen now fitted , window apertures cut out
Now for the dreaded roof, under advisement I made this from 2 pieces of 1.5 mm ply the faces NEXT to each other were scored radially out from the centre as ply will only flex easily one way & it's a compound curvature , glued together with 24hr ARALDITE & strapped down tightly to the top of the frames, next day PERFECT, after releasing from the straps, maintained the required shape
Glue on the roof
Did this upside down as ARALDITE runs when it cures , used ARALDITE thru-out the cabin build for the strength & no movement benefits  <:( two earlier efforts using aliphatic resin were SCRAPPED as they twisted all over the place.
The cabin in all it's glory released & trimmed.
and the engine intakes attached, a coat of resin to seal the wood  . . and on to the next stage.
Can I ask you not to post yet ? as I'll lose track of where I am in this saga, I'll be doing another 4 posts O0
Bill
imsinking
Re: Fantasy Huntress Build
« Reply #1 on: July 07, 2015, 07:47:56 pm »
 O0 Now the swelling's gone down on the finger (one finger typist)continuing on.
Got the basics now, what route to follow ? Seeing some MATRIX characters on EBay I bid on them  :embarrassed: IDIOT ! probably ceramic and heavy , too late now . . .  :o  I won ! 3 figures for £12 inc post , They arrived & WOW, resin figures 1/12 scale fully articulated just what I wanted ($25 each in the States)
Main deck lined / stained / varnished , located a full face bike helmet PolyCarbonate shield , IRIDUM (blue) coated , cut a suitably shaped cardboard template & cut it out
Couldn't heat it up as the coating might have wrecked , >:-o Hernia job bending it cold
Planking sheet lined / stained / varnished & ARALDITED in /console in / doors fitted, Mahogany fillers need to hide the step of the roof , holes drilled , screen tiedowns from stainless strip (Old BOSCH wiper blade insert)
cabin rail holes drilled / cabin painted / windows fitted.  >:-o bad move.
Pulpit next, 3mm & 2mm brass rod brazed it all together on fireproof cement shaped & drilled to the deck contours, feet from brass sheet punched out with a hand witney for the round dome affect then drilled to fit stanchions.
Looks the part.
Paint it, found a suitable winch & had drilled the deck to this template.
Hull paintin' time, made a turntable to make it easier, grey primer then grey gloss, sound's easy ?  >>:-(  NO . .  I'd used Halford's hi build primer & every time I tried to spray over it it either cracked or wrinkled , scraped the lot off & hit it with self-etching primer , CARPLANS grey primer (2 coats) & their 02 Grey gloss (3 coats) I think I came on the forum when I had this problem early in the year.
Contain your EXCITEMENT there's more to come.
Bill
imsinking
« Reply #2 on: July 08, 2015, 01:40:06 am »
HMM , Yeess . . . Moving on . . . .
Finishing the interior now , battery cradles / rudder servo mount. . .
Paint the interior . .
Johnstones Weathershield cream ,slow drying & SMELLS (Still ! )
ESC / Motor / Servo / Fuseblock / Pulpit / Winch all aboard
Tank tests show 12amps stalled with ROBBE 755/5 direct drive to 40X prop, with 2 X 9.6v NiHm packs in series (giving 19.2v @ 5000mah) ESC is a Micro-Gyro FR40 (in non BEC) twin fuse block is Action Elect' P95 indicator Fuses.
Cabin fittings (Macs Mouldings) / screen attached / cabin handrails on & cabin top planking sheet lined / stained & varnished.
OY ! ! SWMBO GIVING ORDERS? I'll need to cut her down to size  <*<
Completed set up, the imitation planking sheet behind the screen looks good.
Cut 12mm section out of Trinity's boots to reach the wheel & throttle.
Another view.
Seems to be a hit with the kid's.
Morfya soon.
Bill
imsinking
« Reply #3 on: July 08, 2015, 10:01:40 am »
Thank's Martin , (their not AFRAID of you YET )
It's MAIDEN voyage time.
Runs 5amps slow / 12amps half / 8amps on the plane . . .BUT . . .
It's too heavy forward, when it comes off the power plunges into the waves, not good.
Looks OK at full speed.
I need to sort it out .
Weighed the ROBBE motor & mount.
It needs to go, along with the FR40 / Fuseblock / radio battery pack, it's go brushless for the solution.
A LEOPARD 2845/5 1780Kv inrunner + 30amp Marine V3 ESC (all water cooled).
It'll be way to fast @ 19v , a pair of VENOM 8.4v 5000mah sticks arrived, & in parallel this time to give 8.4v @ 10000mah combined.
The new layout.
Also went down a prop size to 35s hits 17000rpm @ 8.4v.
Close up view.
This set up is 5amps slow/ 12amps half / 10amps on the plane , still taking a little water over the bows if it slows too quickly , I need to work on my throttle control, takes rough water in it's stride , but the welldeck gets a bit of water after a while.
You BORED yet ?
Nearly there.
Bill
imsinking
« Reply #4 on: July 08, 2015, 08:03:20 pm »
AT LONG LAST !  O0  The final episode .
A front view.
Not happy with the rubber strake it's sponge & it's already cut (right side by the first stanchion)
Stern view.
 >>:-( two days before I realised I'd MISPELT the name ! No way you'll get BECCs lettering off that late, just live with it . . .
the underwater gear.
I'd allowed for up to 50mm props (26mm from keel to C/L of shaft) looks weird with the smaller prop.
Side view.
Lights are in , Nav lights / Back lights in the well deck.
Removable units are tricky to keep watertight, my solution is silicone sealer around the entire cabin base , used EVOSTIK builders silicone (grey) put plenty of masking tape around the deck aperture (vasaline on the tape as well) if it sticks to both  <:(
pressed the cabin down until it's evenly seated all round & leave to set , EVOSTIK's good because it hasn't that evil vinegar smell while it's going off.
Rear fixing is a stainless M6 x 20mm set bolt turned down to 4mm dia at the end.
The hull attachment is an alloy plate.
Dropped the unit back in & drilled a 4mm dia hole thru the rear welldeck wall and the alloy plate then opened up the welldeck hole to 6mm dia.
The front locking device is a quarter turn spring loaded bayonet , disguised as a forward GPS dome.
Cant buy anything had to make it.
Underside of the front latch.
note the silicone seal.
The hull attachment.
An inverted B&Q twintrack alloy rail is the crossbar & a homemade stainless bayonet socket ( I'd made positioning this hard for m'self as I'd fitted the black cabin windows way back & couldn't see , got it eventually)
AND THAT'S IT  %%  The boat is easy to run & looks the part at top speed , around an hours running at high speed, a lot more if it's cruising , rough seas are no problem tho' the welldeck ships a little water . . .
SOOO that's 'SCRATCH BUILDING ' eh , would I do it again ? ?
NOT ON YOUR LIFE ! ! !  %%
Thanks Martin for riding shotgun , please post if you have a mind .
Bill
TomHugill
« Reply #5 on: July 08, 2015, 08:34:24 pm »
Where did you get your imitation planking from?
imsinking
« Reply #6 on: July 08, 2015, 08:44:00 pm »
It's just .75mm ply lined (with a GOOD pen) stained with SIKENS exterior Mahogany wood stain ( goes darker the more coats you put on) finished off with JOHNSTONES Quick dry satin woodstain varnish , need to cut out material so the grain is in the same plane as the plank lines.
Bill
« Reply #7 on: July 08, 2015, 11:21:46 pm »
Great build Bill!   :-))
imsinking
« Reply #8 on: July 09, 2015, 09:50:23 am »
Hmm , anyone looking at this would think I KNEW what I was doing  :embarrassed:  it's been 16 months of pure AGONY . . . you name it , it went wrong, two entire sheets of ply separated , (that made FOUR attempts at the cabin  <:(  ) bad paints , boat balance being wrong , even one of the 9.6v battery packs tried to set fire to the house whilst being charged , on & on . . .
This log's been a sort of THERAPY for me to get it out of my system , nearly threw the towel in a couple of times .
Bill  %%
« Reply #9 on: July 09, 2015, 10:40:19 am »
Well worth the effort Bill!  :-))
What did you make the rubbing strip out off?
What Speed controller?
imsinking
« Reply #10 on: July 09, 2015, 02:16:32 pm »
ERM . . .Ah had to think there , the rubbing strip is from Models By Design, they call it 8mm rubber D section as I've said it's sponge composition prone to being damaged (already cut it on the photo )
I did try to cut down some 8mm O seal  , not much heavier & solid silicone, but no success .
The E S C is LEOPARD's 30amp Marine V3 watercooled, needed to get the programming card as the 'beeps' made no sense , in fact does anyone know how to get into the advanced setting's on this card ? I need to up the reverse speed . . .
When programming it just goes up & down one side of t'card , there's nothing on the instruction sheet how to do it. . .
Bill
imsinking
« Reply #11 on: July 10, 2015, 07:50:05 pm »
A short vid' shot today (Fri 10th July)
https://www.youtube.com/watch?v=YqHv7gUtub4&feature=youtu.be
Looks OK actually , & the batteries were partially run down at this stage , tried to show the 'dipping in' when it comes off the power, can't see it properly  :embarrassed:
Bill
imsinking
« Reply #12 on: July 17, 2015, 07:20:53 pm »
Hmm , after test runs and spotters around the lake consensus of opinion is , that the hull shape is not lending itself to slowing down evenly, snapping the throttle shut is allowing the stern to jump up & make the bows plough into it's own wake . . .
It seems to swivel (near the water outlet on the side) trying extra weight at the stern just makes it ride heavier at the rear and no improvement, so it's out with the 'L' plate's until I learn a smoother technique on the throttle  :embarrassed:
Bill
inertia
« Reply #13 on: July 17, 2015, 07:59:29 pm »
Bill
My advice would be to imagine you're driving the real thing. No sudden full-throttle turns (it will heal over alarmingly), no snapping the throttle shut (it will drop off the plane suddenly). Think ahead and keep everything smooth and wide. This is a rough-water deep-Vee hull; it's not a fast-electric and it won't corner or handle like one; it wasn't designed to do so.
I've built one or two of these myself  8)
Dave M
(Photo by Martin Davis hisself - ta, m'duck!)
imsinking
« Reply #14 on: July 17, 2015, 08:23:53 pm »
Imagine myself ABOARD ? ?  %%  I cant cross the Mersey on a smooth day without getting the collies . . .I used to build ships, I've had no desire to actually RIDE on one ,your pic looks to be riding a LOT higher than my boat, maybe The cabin's overweight ? No matter, I'll live with it  . . . Smoooth turns / slooow sloowly / Up & down / side to side . . .  GROAN . . . .
Bill
JimG
« Reply #15 on: July 17, 2015, 09:30:52 pm »
One way to get round your tendency to slam the throttle open or closed is to fit a servo slow circuit between the Rx and ESC. A quick Google found this http://modelradioworkshop.co.uk/shop/servo-control-devices/servo-slow/ . This will slow the movent down and take up to 15 seconds to go from one end of the stick movement to the other.
Some computer transmitters allow you to program in the servo speed.
Jim
Dundee Model Boat club
inertia
« Reply #16 on: July 18, 2015, 08:30:55 am »
I think the photo was taken from an angle which accentuated the speed. This is more typical of the ride height. The model is only 1/16 scale (23" long); built of liteply and weighs just over a kilo. A friend who is restoring a full-size H31 and crews for another owner says that the model "sits" just right. There's a video taken by Martin at Wicksteed on You Tube - just ask for 'Dave's Huntsman 31'.
BTW I'm currently building a 1/12 scale Huntress 23, which is the same size as the H31 but a larger scale.
imsinking
« Reply #17 on: July 18, 2015, 08:59:01 am »
Jim
Jim , I'd love to do this , BUT you wont live long on our lake with the kiddies & their high speed Chinese torpedo's . . . needs snap responses from the boats to get out of the way  >>:-(  ( I like the way they pile into the wall flat out,  the hull break's up spectacularly  O0 )
Bill
imsinking
« Reply #18 on: July 18, 2015, 09:07:12 am »
Yes , I see the first pic' is in a turn Dave , your second one's not showing much wake disturbance , mine flings it everywhere . . . I'll have to get a right to left shot of  mine to compare with it . . . . {:-{
Bill
imsinking
« Reply #19 on: July 29, 2015, 08:27:17 pm »
 %%  When I was looking for a paint scheme for the boat, I came across this on the FAIREY OWNERS website
 %%  The sea looks pretty calm, wonder why it's airborne . . . .
Bill
« Reply #20 on: July 29, 2015, 08:35:42 pm »
Could be calm with a good swell on the sea.
imsinking
« Reply #21 on: September 04, 2015, 08:50:09 pm »
I've finally connected up the wiring for the lights . . . .
These were a complete package from ' Captain Jacks Models' consisting of Nav' light's / 2 white Hi intensity LED's + ample wiring + resistors and 9v connector .
Exterior view . . .
The Nav' light's FLASH  %%  & can be seen all round , the well deck lights backlight the crew, very effective in the DARK .
The switch is from a discarded brushless ESC I found by our lake , the battery frames are just 2mm brass bent to shape & araldited into the cabin wall , I elected to do it this way as the lights will only be used at Venetian night op's and the 9v battery will last the night out .
Bill
imsinking
« Reply #22 on: September 30, 2015, 04:33:47 pm »
Bear with me guy's IMAGESHACK is playing up . . . .
Bill
« Reply #23 on: September 30, 2015, 05:43:09 pm »
Send me the images Bill, I'll sort them out for you!   :-))
imsinking
« Reply #24 on: October 03, 2015, 09:19:29 am »
Thanks for the offer Martin , (don't think you'd be too happy with 500+ images across all the forums I haunt  %%  ) I seem to have 95% of my pics back , I'll live with that , look's as tho' it's been a major crash with the length of time it took to get up & running again at IMAGESHACK . . . .
Bill
