April 26, 2024, 01:12:33 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Beginners start here...!
Motor
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Motor (Read 1569 times)
Dayo1050
Full Mayhemer
Offline
Spot on
Derby
Motor
on:
September 25, 2015, 05:42:45 pm »
Hi
I have got the CEM900 motor this is the spec they put about it
Nominal Voltage: 12V
Operating Range: 6-18VRPM at Nominal Voltage: 3000No Load Current: 0.4ACurrent at Nominal Voltage: 5.0AStall Current: 20.3ADiameter 51.9mm, Length 69mm, Weight 475gOutput shaft 6.3mm (1/4")Part No: CEM900T
But on the motor it as got
Model CEM900T
DC Range V: 6 - 24 DC Nominal: 12
RPM at DC Nominal: 3000
So what I won't two now is can this motor be run at 24 volts and be ok or does it have to run at 12 volts
Paul
Perkasaman2
Full Mayhemer
Offline
Model Boat Mayhem is Great!
North East
Re: Motor
Reply #1 on:
September 25, 2015, 05:54:08 pm »
The data actually on the motor does state 6 - 24 volts range so running the motor up to 24 volts is ok.
Administrator
Full Mayhemer
Offline
Peterborough, UK
Re: Motor
Reply #2 on:
September 25, 2015, 06:16:01 pm »
Is this for your Puffer build?
At 24v it might be screening for mercy!
http://www.modelboatbits.com/CEM-900-MOTOR-1-1-1-1
Giant Models
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Re: Motor
Reply #3 on:
September 25, 2015, 06:18:30 pm »
If it's for the Puffer 12v will suffice
Up Spirits Stand fast the Holy Ghost.
Dayo1050
Full Mayhemer
Offline
Spot on
Derby
Re: Motor
Reply #4 on:
September 25, 2015, 09:21:29 pm »
Hi
Yes it is for my puffer thanks for that I will stick at 12v
Paul
Print
Pages: [
1
Go Up
« previous
next »
Motor
