Hi Ian ,with the flat bottom and no curves there a lot of space, there are four assorted gel cells in the hull for ballast and because shes wide even a fair in a blow she is very stable, hoping to have a sail next week if everythings ok then its back to the superstructure.
This model started out as lets see if i can build something for steam and the wilesco d48 runs this boat well but thats down to alan and tim, i break it they mend it ! another view of the of the stern the two square openings between the funnels are over the vents in boiler heat shield, parts of the bridge and rear superstructure are designed to let air in and heat out, regards pete
