Author Topic: Alternative to Milliput?  (Read 4426 times)
Norman Castle
« on: October 05, 2015, 06:32:43 pm »
If you wanted to blend two wood surfaces which are joined at right-angles so that you finish up with a radiused joint line (i.e. there is a smooth fillet of filler along it), what would you guys use?
I thought I'd be OK using Milliput, but however much I work it according to the instructions, I don't seem to get on with it.
What else is there that easily shaped/smoothed when being applied and can be sanded once it's gone off?
A positive attitude may not solve all your problems, but with any luck it will annoy enough people to make the effort worthwhile.
Re: Alternative to Milliput?
« Reply #1 on: October 05, 2015, 06:49:37 pm »
You could simply try one of the many other epoxy putties on the market. They come as cylinders and you just cut off a slice and knead it to mix the two parts. They can be smoothed off with a wet finger before they set.
One manufacturer: http://www.jb-weld.co.uk/j-b-weld-epoxy-putty-sticks
« Reply #2 on: October 05, 2015, 08:23:32 pm »
Easy light or top stop filler dead easy to rub down
Arrow5
« Reply #3 on: October 05, 2015, 09:30:19 pm »
Try a few drops of cellulose thinners to your Milliput to make it more workable.   Use an east sand car body repair filler as Stav says.
..well can you land on this?
Arrow5
« Reply #4 on: October 05, 2015, 10:11:48 pm »
For a different Springer have look www.kerrera-ferry.co.uk   Simple, choice of working or fixed bow ranp, single car cargo.
« Reply #5 on: October 05, 2015, 10:20:20 pm »
The Tasmanian Devil has an interesting idea:
...... "time to seal the front deck, I'm sure everyone has their preferred methods of doing this but I will explain the way I like to do it, as it's wood to fibreglass once again I use epoxy but I mix it with talcum powder until it's like peanut butter."
http://www.modelboatmayhem.co.uk/forum/index.php/topic,52388.msg540223.html#msg540223
Norman Castle
« Reply #6 on: October 06, 2015, 07:12:56 am »
Cheers chaps.  I'll see if I can salvage what I screwed up ...
