Any help with imperial threads please?
My latest restore has a 1/8" shaft with a 1" prop.
I was intending to keep the whole propshaft as it looked OK, but unfortunately now I have got quite a way through I have identified that the shaft right up by the motor is not straight; it's too far out to deal with.
I have shortened the shaft as far as I can and the kink is still there, so I have a new 1/8 shaft now, and need to identify the propellers thread.
It's on a 1/8 shaft, with the thread major diameter 1/8 also,
it measures up at 42tpi with the pitch guages and it does look spot on, but I don't actually have a 44tpi to compare it to.
I see UNF is 44tpi on 1/8", was there anything used that was 42?
Was UNF used as a prop shaft thread?
5BA Ive just noticed is 43tpi from the page Ive just found, so it may be that.
Need to try to find a suitable die on eBay or turn the thread on the Myford.
The boat is probably 1970's English.
Any advice appreciated, but changing the prop shaft is now not an option I wish to take.
Jon
