No gas regulator, just slow flow setting at gas valve provides plenty of gas for good heat.
Finished the planking in 1/16 mahogany x about 1/4 or so wide. Before staining, wash the deck with a wet rag. don;t soak it, just enough to moisten the planks. Then I mixed the 'caulk.' I wanted an easy way to fill the seems, so here it is ... I tried tightbond brand but it reacted with the flat black model masters acrylic. Then I tried Elmers carpenters glue. Perfect mix. Use about 1/2 - 3/4 oz glue with 1/4 - 1/3 of that in flat black paint, and a few drops of water. mix up real well. then pour on damp deck and squeegee into all grooves. be sure to get into all the spaces! Does not matter how messy you are. The glue does not penetrate into the mahogany very well, but it is thick enough to fill the cracks....
when done, place on some scrap wood so that the deck does not stick to table top or paper.... stay tuned for more...
